PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Turbo
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 19-02-2008, 11:12 AM   #121
antony215
Escort Rs Turbo
antony215's Avatar
Trader Score: (0)
antony215 is an unknown quantity at this point
Yeah but you should be able to get them from fords cheap Have a look on here shows you how and what you need
http://www.rsbible.co.uk/
__________________
antony215 is offline   Reply With Quote
Old 19-02-2008, 11:28 AM   #122
SafeChav
SafeChav's Avatar
Trader Score: (0)
SafeChav is an unknown quantity at this point
Send a message via MSN to SafeChav
Quote:
Originally Posted by MorryRS
Quote:
Originally Posted by antony215
Safechav
I have 2WD Discs and calipers to fit to my S2 . I have offered them up and as mentioned before i looks like i need to machine the caliper a bit to fit . Is this the way to do it from your experience as you have them fitted??
Many thanks
Kenny
4mm needs to be machined off the mating edge of the caliper
Cool exactly 4mm is it -milled i suppose -then fix the caliper on with a bolt and nut??
I bought mine as a set that had already been fitted to an Orion, i did measure up ages ago and i think i measured something like 3.7 or 4.7mm, 4mm should be fine though.
Anyway thats the easy part of the conversion. Place the caliper against the hub and you will see the holes are ever so slightly not in line, its a tiny amount but i did find when it was time to put the bolts in after tapping the M12 thread into the hubs the bolts were awkward to get in, i had to wind both bolts in together to start and then do up each bolt bit by bit, otherwise they tried to go in on the piss.
Then once you've done then you'll more then likely scream when you realise the brake pipe connection points out directly at the CV joint, you'll need some 90 degree adapters in order to fit pipes and clear the CV joint.
__________________
SafeChav is offline   Reply With Quote
Old 19-02-2008, 11:30 AM   #123
SafeChav
SafeChav's Avatar
Trader Score: (0)
Just spotted you ask about bolts. Just go to your local fastening place and get some HIGH TENSILE M12 cap head bolts, i was advised the cap head bolts bolts over hex bolts, apparently stronger although i can't possibly comment myself.
__________________
Old 19-02-2008, 11:30 AM   #124
MorryRS
MorryRS's Avatar
Trader Score: (0)
MorryRS is an unknown quantity at this point
Send a message via MSN to MorryRS
Will check it at home - cant get into it at work , only get the front page
__________________
White S2 Turbo R.I.P
Miami Blue S2 Turbo Still here
MorryRS is offline   Reply With Quote
Old 19-02-2008, 08:14 PM   #125
danskfocus
Trader Score: (0)
danskfocus is an unknown quantity at this point
__________________
danskfocus is offline   Reply With Quote
Old 20-02-2008, 08:03 AM   #126
MorryRS
MorryRS's Avatar
Trader Score: (0)
Quote:
Originally Posted by SafeChav
Safechav
Many thanks
Kenny
Cool that clarifys things up - i will take them into my work then and get the caliper machined and the hub taped to M12 . Yeah heard about the brake hoses , ordered some off Mike Rainbird
__________________
Old 28-02-2008, 09:05 PM   #127
mercury xr
Trader Score: (0)
mercury xr is an unknown quantity at this point
Send a message via MSN to mercury xr
If I got Granada Scorpio Cosworth Callipers , do they use the same pads as a sierra cosworth, and escort or are they all slightly different?
__________________
Which gimp changed this?
mercury xr is offline   Reply With Quote
Old 06-04-2008, 04:23 PM   #128
mentalasanything
Trader Score: (0)
mentalasanything is an unknown quantity at this point
Send a message via MSN to mentalasanything
Guy's, just updated the thread to show a rear brake conversion, what you think??
Lee
mentalasanything is offline   Reply With Quote
Old 06-04-2008, 09:07 PM   #129
sexr3i
isn't it
sexr3i's Avatar
Trader Score: (0)
sexr3i is an unknown quantity at this point
Send a message via MSN to sexr3i
Sound, but if you buy the oddkidd rear brackets you don't need to grind the corners off the bolts, they come with countersunk holes and bolts to fit em. But oddkidds kit needs slightly longer rear hoses, with the "mad for it" brackets you just use another front set of mk4 escort ones. With both mad for it and oddkidds you get all spacers etc required.
And the mk5 RS2000 handbrake cable definately fits proper. You just use the rear section up to the half moon. How come it took you so long? It's about 6 bolts each side. With a tea break and bleeding mine took about an hour a side.
How come you used solid disks too? Mine are vented all round.
Mercury - Same pads.
__________________
89 3i zetec
mk3 toy
http://www.passionford.com/forum/viewtopic.php?t=161433
sexr3i is offline   Reply With Quote
Old 06-04-2008, 10:46 PM   #130
mentalasanything
Trader Score: (0)
Quote:
Definately didn't fit mine, couldn't even get enough cable to come out to wrap aroud the handbrake arm on the caliper. I'd never seen one like it before, 2 cables and a half moon that the cables fitted into....
On the other hand, I bought an Escort Cossie handbrake cable today, a one piece jobbie which appears to be the one I was after, so we'll see when I fit it next weekend. It's identical to the RS Turbo one even has the adjusters on the one side near the half moon, except with ends to fit calipers.
It was a combination of not having the correct sized disks, waiting for new disks to arrive, not having spacers and waiting for my uncle to make them, when you count up the time spent on the car, it really didn't take too long, an hour and a half.
Vented disks are off the Escos/Sapph cossie 4x4, the calipers you have must be off one of those, the calipers I have are off a 2wd Cosworth/XR4x4 hence solid disks.
Old 06-04-2008, 11:37 PM   #131
sexr3i
isn't it
sexr3i's Avatar
Trader Score: (0)
The escort cossie sounds more like the one you should have been given in the first place, one cable that hooks round the half moon. Think the mk6 RS2000 ones are different, they may have given you that one?
Yeah I've got 4x4 cos calipers. Didn't know you had 2wd.
__________________
89 3i zetec
mk3 toy
Old 07-04-2008, 10:04 AM   #132
mentalasanything
Trader Score: (0)
That's the fella! Dont know what went wrong there then, perhaps it was for a mk6.
Yep 2wd calipers (Edited the guide to show now!), they're cheaper and more than adequate for my usage, the only reason I've upgraded is because the pistons were nackered on the drum setup.
Lee
Old 01-05-2008, 11:53 PM   #133
rsvmad1
rsvmad1's Avatar
Trader Score: (0)
rsvmad1 is on a distinguished road
Smile rs van mk4 rear disc conversion
ort lads i just bought rear axle and leafs for my mk4 van and apparently all the hard work is done.(the hubs are off and plates welded on for calipers and the fitments are there for discs and wheels) i have pix but dont no how to ad them to messages. Apparently All i need is cossie 2wd discs and calipers.(and brake bias valve to stop it lockin up if wanted). Does any1 now if i need anything else. Also i need a pair of front lowerin springs(60mil) may buy struts aswell Cheers lads
rsvmad1 is offline   Reply With Quote
Old 07-09-2008, 10:43 AM   #134
mattyred s2
mattyred s2's Avatar
Trader Score: (0)
mattyred s2 is on a distinguished road
i did the rear brake coversion on mine earlier this year, i fiitted a 3 door cozzie handbrake cable on mine couldn't get the right mk5 rs2000 handbrake cable (think theres three different one's for the rs2000) local motor factor could only get hold of two types both wrong ones ...
mattyred s2 is offline   Reply With Quote
Old 24-09-2008, 09:05 PM   #135
studabear
studabear's Avatar
Trader Score: (0)
studabear is on a distinguished road
has anyone got any links for getting the oddkidd rear conversion bracket kit, I'm about to start converting my turbo cabriolet, I've got my front 4x4 calipers and like the sound of the oddkidd kit mentioned earlier in this thread, I'm not keen on the idea of grinding the bolt heads back to clear the hubs
__________________
Megasquirt project underway, hope my clutch can stand 20psi of boost
studabear is offline   Reply With Quote
Old 24-10-2008, 10:31 PM   #136
StuRST
StuRST's Avatar
Trader Score: (0)
StuRST is an unknown quantity at this point
Quote:
what length do these need to be?
StuRST is offline   Reply With Quote
Old 01-11-2008, 08:28 PM   #137
rst1990
Trader Score: (0)
rst1990 is an unknown quantity at this point
good thread here mate used it for my rear disc conversion and it helped alot in sourceing the parts the only thing that you dont mention is that the rear disc reduces the lengh of the wheel bolt going into the wheel because the old drum is about 5mm thick but the rear disc is about half an inch thick so your reduceing the amount that the bolt goes in to the thread. thought i might mention this as after all they do hold your wheel on. i know that the bolt feels tight when its in but its not in the thread enough.
rst1990 is offline   Reply With Quote
Old 02-11-2008, 08:50 AM   #138
rs shawn
S1 Database Editor
rs shawn's Avatar
Trader Score: (0)
rs shawn is an unknown quantity at this point
Send a message via MSN to rs shawn
Did you buy new wheel bolts then? What length did you go to?
__________________
D plate S1
Click Here For The Series One Picture Database
www.seriesoneturbo.co.uk - the site that caters for all Mk3 Escorts.
rs shawn is offline   Reply With Quote
Old 02-11-2008, 11:08 AM   #139
mentalasanything
Trader Score: (0)
I havent got standard wheelbolts so I didn't notice. I have the speedshack ones with the collars.
Lee
Old 03-11-2008, 05:51 PM   #140
rst1990
Trader Score: (0)
Quote:
yer bought new wheel bolts from elites tyres and wheels cost a tenner i got the new wheel bolts half inch longer than the originals they also come collard.
Old 04-11-2008, 10:25 AM   #141
rs shawn
S1 Database Editor
rs shawn's Avatar
Trader Score: (0)
1/2" longer.
Thanks, haven't done this myself but sure it will come in useful to others.
__________________
D plate S1
Old 02-12-2008, 10:29 PM   #142
escombi
Trader Score: (0)
escombi is an unknown quantity at this point
Send a message via MSN to escombi
Does it matter if I use 253mm solid disks on the rear? or do I have to use 273mm? wot disks are the conversion plates made for
escombi is offline   Reply With Quote
Old 04-12-2008, 10:49 AM   #143
ricky_2006
Trader Score: (0)
ricky_2006 is an unknown quantity at this point
can you put the standard s2 15" wheels on if uprated. coz i got sum 16" tsw 90's wheels on and want to change them bk to standard?
ricky_2006 is offline   Reply With Quote
Old 04-12-2008, 10:56 AM   #144
mentalasanything
Trader Score: (0)
Quote:
Yes, see the pics on the first page
Lee
Old 04-12-2008, 10:57 AM   #145
rs shawn
S1 Database Editor
rs shawn's Avatar
Trader Score: (0)
First post mate...
__________________
D plate S1
Old 10-12-2008, 08:04 PM   #146
escombi
Trader Score: (0)
Thumbs up
does anyone no wot other calipers and carriers ae the same as 4x4 cossie front and 2wd rear thanks for any help
Old 10-01-2009, 07:35 PM   #147
kidsRS
"Ill check the stock"
kidsRS's Avatar
Trader Score: (6)
kidsRS is on a distinguished road
Is it the same process in fitting the cosworth 4 pots to the front of a s1 or 2?
kidsRS is offline   Reply With Quote
Old 26-01-2009, 01:39 PM   #148
xrmalin
Trader Score: (0)
xrmalin is an unknown quantity at this point
Quote:
Why dont you read the rest of the thread and you'll know its not. You need to have the calipers machined 4mm off the mounting face some thing like this
you can also see in the picture you need to modify your bake hose to a bolt and banjo instead of just screwing it in like like the ones on your car at the minute.
mark.
__________________
Check out my xr3i Re-build here
http://passionford.com/forum/restora...e-rebuild.html
xrmalin is offline   Reply With Quote
Old 09-03-2009, 08:08 PM   #149
martinmilne
Trader Score: (0)
martinmilne is an unknown quantity at this point
Send a message via MSN to martinmilne
on mine i got the 2wd discs with std turbo callipers just need some brackets to fit the calliper after works very well much better than std discs and alot cheaper then buyin cossie callipers too
__________________
martinmilne is offline   Reply With Quote
Old 18-04-2009, 07:48 PM   #150
Rs Adz
Trader Score: (0)
Rs Adz is an unknown quantity at this point
briliant thread guys one question would anything change on this guide doing it on a base model mk3 instead of a turbo and if i do rear discs do i need a brake biase valve cheers
__________________
check my mrk3 escort thread
http://passionford.com/forum/showthr...45#post3636445
Rs Adz is offline   Reply With Quote
Old 19-04-2009, 11:32 AM   #151
xrmalin
Trader Score: (0)
same process mate wether it be a turbo or not
bias valve theres alot of mixed views some say you need one some say you dont
__________________
Old 20-04-2009, 08:38 PM   #152
StephenC
..BS Motorsport..
StephenC's Avatar
Trader Score: (0)
StephenC is on a distinguished road
Which of these brackets would be best???
clicky
or
clicky
__________________
"be good, or be good at it..."
my photos on --> FlickR or view them in style at fluidr
StephenC is offline   Reply With Quote
Old 20-04-2009, 10:43 PM   #153
B16CVH
B16CVH's Avatar
Trader Score: (0)
B16CVH is on a distinguished road
Quote:
clicky
or
clicky
Ive got the bottom ones
__________________
If it do dont have a 6-link you aint driving hard enough
240BHP CVH Powered westfield project now finished
B16CVH is offline   Reply With Quote
Old 21-04-2009, 06:48 AM   #154
StephenC
..BS Motorsport..
StephenC's Avatar
Trader Score: (0)
do you know if they suit 4x4 discs?
__________________
Old 21-04-2009, 10:51 AM   #155
xrmalin
Trader Score: (0)
clicky
or
clicky
ive got the bottom ones aswell i think the brackets are the same wether you want to run solid disc's or vented like the 4x4 its just the calipers that are differant 2wd calipers for solid disc's 4x4 for vented disc's
mark.
__________________
Old 21-04-2009, 04:16 PM   #156
StephenC
..BS Motorsport..
StephenC's Avatar
Trader Score: (0)
cheers gents
__________________
Old 15-06-2009, 01:51 PM   #157
trooper1991
trooper1991's Avatar
Trader Score: (0)
trooper1991 is on a distinguished road
hi there can any one confirm which brake hose i need off a vw and which braided brake hoses i need also does any know the part number for the actual handbrake needed many thanks chris
trooper1991 is offline   Reply With Quote
Old 05-09-2009, 05:46 PM   #158
makaveli96
makaveli96's Avatar
Trader Score: (0)
makaveli96 is an unknown quantity at this point
Hi guys I have just collected every thing needed to do a cossie 4x4 rear brake disc conversion, here are some pictures and how much I’ve spent on parts.
Brand new genuine Cosworth 4x4 callipers £130
Brand new 20 groove vented CRN brake discs £70
Brand new EBC greenstuff pads £40
Brand new Conversion Brackets, Bolts and spacers £30
Brand new Goodridge braided rear brake pipe £32
Brand new mk5 RS2000 hand brake cables £28
Total £330
And at the front I have
Tarox G88 40 Grove ventilated standard size discs.
Standard size Cailpers painted in Gold & EBC Greenstuff Pads
Front Goodridge braided brake lines
ABS system removed
Picture of the fronts
And these are the cosworth 4x4 rear brakes
As I left the garage I used the brakes gently and straight away I can feel the differents at the back feels a lot more stronger than the rear brake shoes that I had removed, I’ve kind of almost used the brakes to it’s fullest and do have to say it brakes perfect and well balanced with the fronts with no locking up or brake noise what so ever, so the new rear standard ford compensator valves that I had fitted last year do work well and no need for upgrading to the bias valves or even upgrading to much bigger brakes at the front here’s a few pictures of them fitted I’m well pleased of them what a result.
__________________
186bhp with 205ft at 15psi
Italy World Cup Winners 34* 38* 82* 06*
makaveli96 is offline   Reply With Quote
Old 16-11-2009, 07:50 PM   #159
morph
morph's Avatar
Trader Score: (1)
morph is on a distinguished road
had problems fitting mine as the caliper carriers were toucking the outer edge of the discs and could not see why? are there slightly bigger disc available for the 2wd cossie? as i cant understand why these are touching only possiblity is that my discs are bigger than 283mm!
morph is offline   Reply With Quote
Old 16-11-2009, 07:55 PM   #160
morph
morph's Avatar
Trader Score: (1)
Total £330
ABS system removed
i dont understand how your car has not managed to lock up the rears as they are stronger brakes?
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
