| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#81 | ||||
S1 Database Editor
__________________
D plate S1 ![]() Click Here For The Series One Picture Database www.seriesoneturbo.co.uk - the site that caters for all Mk3 Escorts. |
#82 |
are you sure they are 1mm washers as they look wider
if so where on earth can i find some , i have been everywhere and the smallest i could find were 2.4 mm
__________________
#83 |
I have a Rs Turbo series 1, i was just wondering will the cossie callipers fit ok behind the standard wheels. I was looking into doing the conversion as the standard brakes are terible!!!! I have not seen any second hand callipers for sale lately, i was at Ford ......fair and no joy in parts and spairs.
__________________
RS Turbo series 1 |
#84 |
S1 Database Editor
Pretty certain they will fit.
![]() Get some pics up of your car mate.
__________________
#85 |
Fleet Manager
can u use 4x4 discs?
__________________
![]() Click to see my RS Turbo project http://passionford.com/forum/showthr..._g#post3406438 |
#86 | |
Trader Score: (0)
Rep Power: 20 ![]() |
Quote:
marky_g - don't think so, but don't quote me. They will be a different size i expect.
__________________
#87 |
Fleet Manager
what braided lines do i use 4x4 cossie or rs turbo
__________________
#88 | |
Quote:
Lee |
#89 |
Alright guys, ive read this a few times now and its as clear as mud to me at the min...maybe im to tired or could be im missin a brain cell at the min!!!
I have escort cosworth discs and calipers to go on my series 1 what do you recon have i bought the right stuff or dropped a bollock??? |
#90 | |
S1 Database Editor
Quote:
__________________
#91 |
How do you fit the cossie 4 pots to a S2 ?
I am needing a vast improvement in my brakes, im sure i read it somewhere before but i have forgot. Any info appreciated
__________________
White S2 Turbo R.I.P Miami Blue S2 Turbo Still here |
#92 |
im trying to fit 4pot cossy to a mk4 escort at the min
from what ive found you need to machine about 4-5mm ish off the mount then it just bolts on im using 2wd disks i will let you know how i get on
__________________
playstation 3 username = anodised crap username i know my real name is Lewis im dyslexic but i do try |
#93 |
anodised
look foward to hearing how you get on with it . any info would be useful
__________________
#94 | |
Quote:
its not as easy as the 4x4 brakes to do cause thats what i did have on it
__________________
#95 |
I have a mk4 XR3i, hoping to have bigish turbo conversion soon n all that jazz, so will be wanting bigger brakes what i was wondering is;
is there a differance between RS Turbo braided brake hoses and XR3i hoses? Cheers |
#96 | ||
Quote:
__________________
#97 |
ive got 2wd discs and calipers on the front of my erst s1 all you do is grind 4-5mm off the inside of the caliper mounting face and then get suitable lock nuts and bolts to hold them on but ive had to use 5mm wheel spacers as ive got 17" softlines on because the caliper was to close to the wheel as is when fitting softlines on a 2wd cos
#98 |
Hello guys,
I went to a race and rally shop in the netherlands and they can supply me the ferrodo D2500 serie from the 4x4 and the also can supply grooved and drilled 283 mm discs. The problem is they can supply it in two different hights around 44 mm and 56 mm hight of the total disc. Can somebody tell me which hight i need to order, because i don't want to order the wrong ones because they are specially orderd. And it takes 4 to 5 weeks to get them Please help me
__________________
" Dream as if you live forever, live as if you die today. " ![]() Check my project on http://passionford.com/forum/restorations-rebuilds-and-projects/207111-big-s2-rs-turbo-project-finished-lots-of-pics.html |
#99 |
isn't it
never had to use a spacer washer on my set...
![]() want a guide on the rears?
#100 |
Yer do a guide on the rears chap!
__________________
Which gimp changed this? |
#101 |
up for the question
__________________
" Dream as if you live forever, live as if you die today. " ![]() Check my project on http://passionford.com/forum/showthread.php?t=207111 |
#102 |
bump
Need to order them quick
__________________
#103 |
still no1?
__________________
#104 |
isn't it
what is the disk height? |
#105 | |
Quote:
I'm almost 100% sure it's 55 but i want to know for sure http://autosportcompany.nl/viewdetai...6403&afdid=515 Here you got a dutch site that gives 55 mm, but i don't know why they also got the around 44 total hight...
__________________
#106 |
isn't it
ahhhh, offset...
44mm will be the 4x4 disks then I reckon. |
#107 | |
Quote:
__________________
#108 |
Fleet Manager
will all v6 mondeo mk2 calipers be the same as 4x4/ecos or just the st's
__________________
#109 |
Fleet Manager
need a def answer on this as i have a 2 blokes waiting on replys
so st mondeo/v6 and granny cossie/scorpio will be ok????
__________________
#110 |
Fleet Manager
can no one shead anymore light on this plesae about the mondy/scporio calipers?
__________________
#111 | |
Trader Score: (0)
Quote:
__________________
#112 |
isn't it
who says? Thread is about 4x4 calipers all round? If you use 2wd calipers you need the opposite to a spacer, to grind yer hub carrier...
What you got fitted on that cab of yours? |
#113 | |
isn't it
Quote:
#114 | |
Trader Score: (0)
Quote:
__________________
#115 |
Safechav
I have 2WD Discs and calipers to fit to my S2 . I have offered them up and as mentioned before i looks like i need to machine the caliper a bit to fit . Is this the way to do it from your experience as you have them fitted?? Many thanks Kenny
__________________
#116 |
If I want to use 283mm Sierra Cosworth 2WD brake discs on an MK4 with the original Escort RST S2 calipers, then I have to use front caliper mounting brackets, as shown here: http://www.rsrich.force9.co.uk/zetec-turbo/sale.htm
Unfortunately they do not answer to any questions, or orders. Could anyone help me, and tell me the measuements of this bracket, so I can have it done by a local shop? |
#117 | |
Escort Rs Turbo
Quote:
__________________
#118 | ||
Quote:
__________________
#119 |
Escort Rs Turbo
The hubs need the holes taped to M12
__________________
#120 |
Right is that to use the 2wd caliper bolts which i dont have ?. LOL
__________________
| Display Modes | |
