Mk3 & Mk4 rear brakes
It Wasnt Me!
Any difference in size?
Think mine needs a rear cylinder as pedle isnt firm and sinks to the floor with car off or running.
got braded lines all round aswell, how much would braded lines be from the master cylinder-calipers/cylinders be?
Also, if I was to get rid of the rear load sensor valve, what woul di replace with apart from a bias valve, im sure the twins got inline valves or something?
Plan on upgrading to braded lines from Mk5 RS2000/130ps master cylinder, cossie discs and S2 calipers
The size of the rear cylinders varied from year to year. I'd just go with the largest ones as the bias is usually far too much to the front. Of course I have no idea what brakes you have....
It Wasnt Me!
Ive got standard S1 brake setup
What model/year did the largest cylinders come from? and these are the ones to get? drums the same size too?
Im assuming it's the cylinders or one that's gone too, car doesnt move much so i'd guess on it being them!
Originally Posted by shane
To answer ur first post i think the s2's rear discs were larger!
It Wasnt Me!
Yea will need to check for brake fluid, cant work out why else apart from a leak the pedal would just go to the floor. . hmm
so to upgrade the rear brakes you need the backplates/shoes etc basically all the parts to go with it, or is it jus a case of swapping the drums?
XR3I & RS TURBO have different size rear drums - xr are 8" & turbo are 9" on series 2 - so i would imagine the series 1 rear drums are 8" - you would need rear back plates, new shoes,new cylinders & new fitting kit - can get real cheap at a motor factors like partco......
Hope this helps........
19.05mm diameter is the one one want unless you want to use 20.xx or 22.22 cylinders from other Fords.
The 19.05mm was used in pretty much all 1.6 Escorts 80-90.
It Wasnt Me!
Andy_R, cheers andy will have a red on that! Im sure the twins when restoring their underside placed a valve either side at the rear from ford, will need to ask!
vroomtshh, dingy that then, can get copper ones for free cheers for the info tho
It Wasnt Me!
Lucid, Thats just too much work
S2 brakes with cossie discs will be cheep and cheerfull and easier to get hold of i'd assume
Might be able to gt sierra xr4x4 stuff, dunno if it'll be any use but. . .we'll see
Originally Posted by Andy_R
Dave a Brake Proportioning valve(click) can be used if you plan on replacing the rear load sensor valve.
Not sure what difference it does in practice though. Perhaps not that much really. S1 as XR3i has restricting valves for the rear brakes in the engine bay, but they operate based on decceleration. The more a car decellerates, the more the pressure is restricted.
S2 has restricting valves bolted next to the rear suspension arms and these restrict the pressure when the arms are moving down . This of course happens when the rear end lifts up under braking and gets light.
So they more or less do the same thing, but are based in a completely different principle.
Jesse, the restrictors in the engine bay are fixed rate, its the valves on the later cars which restrict on deceleration.
Davvy, look on your passenger side inner wing and you will see 2 small cannisters, those are your fixed rate rear brake compensators, series 1's dont have load apportioning valves
It Wasnt Me!
Nice, Ive noticed them on S1's aswell and never even thought, I just assumed it ould have the load sensor ones at the back too
So what would be the plan if i wanted rear disc conversion, just out of interest, would i get different valves or are these ones fine on their own?
Never will you find a car with both unless someone has been silly enough to do a bit of DIY wrong.
If your doing the disc conversion just smash it on, they're all the same.
HOWEVER, as most find you will probably experience aswell, putting discs on the back makes the pedal very poor, being as you have a 22mm master cylinder.
There are a couple of people ive spoken to who claim to run a 22mm item and have a good pedal and i have no reason not to believe them, but the majority of people have the same problem as me and i currently have a 23mm.......so just don't overlook this
It Wasnt Me!
Im gonna be fitting the rs2000/130ps xr master cylinder, bigger than the s2, cant mind what mm it is tho, prob wont fit discs n calipers as its pretty pointless imo!
S2 calipers
cossie 2wd discs
spacer brackets
S2 rear set up
rs2K master cylinder
got braded lines already
hopefully get new plastic bush things for the brake pedal bar thing that goes along the bulkhead aswell as their penny's
is it worth getting a new servo?
S2 calipers
cossie 2wd discs
spacer brackets
S2 rear set up
JesseT, how does this principal work on later cars then like MK5 escorts, that have a tiny inline compensator screwed directly into the MS, and they are completely horizontal? I see what you are saying though...
track.focus'd
12-08-2015 05:53 PM
