Where can i find...
Old 15-09-2005, 09:32 AM
Blocos
Blocos's Avatar
Default Where can i find...
Hello
where can I find map sensor 3 bar and actuator -31 for
my escort small turbo
thank's for help
Matthieu
france
Old 15-09-2005, 02:09 PM
Blocos
Blocos's Avatar
Old 15-09-2005, 02:27 PM
Kelv
Almost there!
Kelv's Avatar
Try woodford Garage
01803-863958
www.cosworth.info
3 Bar MAP aprox Ł65 & -31 aprox Ł85
Old 15-09-2005, 02:51 PM
Dave Henshall
Dave Henshall's Avatar
but, dotn forget a small turbo doesnt use a map sensor, unless its been converted to a webber ecu..
Old 15-09-2005, 03:56 PM
THE RADMAN
THE RADMAN's Avatar
it does,but its a diff type dave
Old 15-09-2005, 04:22 PM
Dave Henshall
sure? didnt think it used manifold pressure, rather Mass Air Flow by means of the metering head at the airfilter..?
Old 15-09-2005, 04:36 PM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
there is a map sensor its a 2.5 bar i'm sure its on the chassis leg if i remember corrrectly... looks like this.....
Old 15-09-2005, 06:21 PM
Blocos
Blocos's Avatar
this picture is not an escort cosworth T25 ???
Dave are you sur there is not?
Old 15-09-2005, 06:45 PM
Azrael
Azrael's Avatar
There is MAP sensor of course on small turbo car. But I don't think there is a point to upgrade one as EEC - IV can't be reprogrammed for that sort of boost easily enough.
Old 15-09-2005, 09:40 PM
adamski frst
this is not a picture OF a T25 small turrbo cossie but IS a pic of the small turbo map sensor my mate put it on his uprated fiesta turbo!!!
as i said its on the inlet side on the chassis leg i think but as also been said its not worth upgrading using the small turbo management, not sure why just what few tuners told me....
Old 16-09-2005, 07:57 AM
Dave Henshall
so (its another school day for me ... ) what does the airflow meter actually do it the small turbo ecu is measuring manifold pressure - does it use a combination of both? i've had a look on microcat and it lists an ACT and ECT as seperate sensors (obviosly) but i cant see a map sensor....?
is the small turbo on the same as the large turbo one (2.5bar) but with a plastic cover over the top...?
Old 16-09-2005, 08:01 AM
Azrael
Azrael's Avatar
Stu was explaining this nce to me on forums -> you can look in archives. Generally ECu uses MAP sensor signal to calculate boost strategies, control maximum boost and things like that. Uses MAF to calculate load. There are also different error modes and things like that. The car is driveble (won't idle though in most cases) without MAF because it has it's MAP.
Don't think so.
Old 16-09-2005, 08:04 AM
Dave Henshall
Old 16-09-2005, 09:25 AM
adamski frst
Old 16-09-2005, 09:27 AM
Azrael
Azrael's Avatar
By the way - only from curiosity - schouldnt the topic be "Where can I find..." ?
Old 16-09-2005, 09:35 AM
Blocos
Blocos's Avatar
it should be
escuse me for my english
Old 16-09-2005, 09:37 AM
Azrael
Azrael's Avatar
Oh. OK. I am not a native speak so I try to track such things as strange language forms...
Old 16-09-2005, 09:55 AM
Blocos
Blocos's Avatar
Sorry but I don't understand all
there is no MAP and there is a MAF??
is MAF the ''debimetre d'air''??
thank
Old 16-09-2005, 09:57 AM
Azrael
Azrael's Avatar
There are BOTH.
MAF is "Mass air flow sensor" or something like that. d'air suggests it's something like that but I don't know enough French to know. Ask user "Petrucci" he's French and speaks perfect English
Old 16-09-2005, 10:05 AM
Blocos
Blocos's Avatar
Ok thank you
Old 16-09-2005, 10:07 AM
Azrael
Azrael's Avatar
OK no problems mate A pleasure to help.
ryan_gwa
71
31-05-2012 03:30 PM
TIFF
24
10-03-2010 06:47 PM
boost mad
13
01-02-2010 08:26 PM
Quick Reply: Where can i find...
