Can someone help misfire with my escorth T25 small turbo
Old 06-09-2005, 04:48 PM
danielT28
danielT28's Avatar
Default Can someone help misfire with my escorth T25 small turbo
hello,
Can someone help me with my escorth T25 small turbo with a stage 2 GGR chip.
It has a misfire with full trothle and starts about after 1,2 bar turbo pressure.
I have replaced the spark plugs 3 times already (gap at ,65mm) but this seems not to be te problem.
Has someone an idea??
Greetings from belgium
Daniel
Old 06-09-2005, 05:41 PM
cossymad
cossymad's Avatar
What plugs are you running Daniel?
You could do to go down a heat range, as this usually eliminates bad spark, but can cause slighly rough idling.
If not check wiring to coil packs, and the leads themselves
hris
Old 06-09-2005, 07:08 PM
georgie1
georgie1's Avatar
check ur coils i was gettng misfire on my small turbo escort cosworth changed the coils it ok now
Old 07-09-2005, 08:02 AM
IMOL
IMOL's Avatar
I have had similar problems.
I tried the plugs , then the coil , then the plug leads , then the fuel system, crank sensor and it endid up to be the lambda probe of all things
Hope you find it !!
Old 07-09-2005, 10:41 AM
ryan_belfast
ryan_belfast's Avatar
It can be one of many things....
Its currently happening on my escort cosworth too, but i think mine is due to the gap on the plugs. I will check this and see if it sorts it. Thing with small turbo cosworths is you can only use a certain type of spark plug, its either standard small turbo or standard big turbo ones you use, cant remember, hopefully STU comes on here and sorts all.
Old 07-09-2005, 11:30 PM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
PLUG GAPS!!! had the exact problem on mine few weeks back halved the gaps and runs like a dream now!!!!!
Old 14-09-2005, 11:09 AM
danielT28
danielT28's Avatar
hris
hello,
I already tried these sparkplugs "NP DENSO PK20 PR P8" and "MOTORCRAFT AGPR12PP" with a gap of 0,65mm but the problem remains (misfire at 1,2 bar). Is there a possibility to check if the coils are malfunctioning (if they are still ok?).
Because i'm planning to rebuild my engine to a big turbo version, and maybe it's stuped to put a lot of money in it now.
The leads seem fine to me.
Maybe I can add this; since I'm having problems with misfire, I have also distortion on my radio from my engine (I mean, I can hear my engine trough my radio)
Old 14-09-2005, 12:09 PM
red october
red october's Avatar
deja vu!
Old 14-09-2005, 12:41 PM
ajjames
ajjames's Avatar
i also sometimes hear my engine noise coming through my radio dont no why though
Old 15-09-2005, 09:25 AM
Blocos
Blocos's Avatar
Salut daniel ,
qu est ce que tu as utilisé comme bougies car si j ai bien compris
tu as un boitier ggr
si oui tu devrai utiliser des bosch f3cs ou champion qc57c
as tu une map 3bars?
Old 22-09-2005, 03:05 PM
danielT28
danielT28's Avatar
hris
hello,
j.hammond1
30
31-10-2021 05:28 PM
3i Jim
20-11-2015 05:12 AM
Matt Baxter
16-09-2015 08:30 PM
Cosnada
27-08-2015 09:15 AM
IAN RS2k
18-08-2015 07:51 PM
Quick Reply: Can someone help misfire with my escorth T25 small turbo
