View Poll Results: hi-spec or AP
Voters: 57. You may not vote on this poll
AP or hi-spec???
AP or hi-spec???
thinking of getting some new brakes what you think i should go for?
Also i have a set of 18inch comps so what size can i fit behind them?
i got some hi spec 355 and 6 pots, for mine,tried fitting them and they fouled the t/r/ends,also the caliper wouldnt fit as it touched the disc,the only way it would have fitted was to machine some off the bracket to allow it to move further outwards! it also touched the top of the disc,they went straight back,i lost out on £20 postage but eventually got my cash back after a couple of weeks,ended up buying ap 330 and 4 pots- perfect fit and precision made
Originally Posted by bigpower
Here's my vote!.................
Aren't your discs fitted the wrong way around? The grooves should turn in the opposite direction I believe. At least if I look at my AP's, discs are marked with 'left' and 'right'.
Jo,
They were marked L & R?
If they are i'll change them, but sure there right, seen others this way????????
I dont thrash the car, so would it make loads of differance?
Jo,
I have no idea if it makes any differance, but I 'm going to follow the L and R mark. I guess AP put that there for a reason.
It should be as in the pic, (picture of front left side of the car)
AP and 380's
Disk rotation has nothing to do with the grooves on the outside of the disk, these are only there to clean the pads, you must look at the inner "veins" of the disk, these must run backwards to force out the hot air and not cut into the air as many people think
veins deffo run backwards!!!
Saves me a job of changing them around !!!! Thought they were right to start with tho, but Jo made me think for a minute?
AP AP AP
AP AP AP
well i have had 355 6 pot from hi spec on my car for a long time and they have never let me down and i have given them some hard times in the past, the problem with hi spec is not the products its the staff they tell fibs about when you will get your brake kits and evern send out the wrong kits to you but once fitted i have found mine to be well up to the job.
I have just change to ap as i now have fitted some 380 floating discs and 6 pots so i wait to see what they are like, also putting some 330 4 pots on the rear
old brakes
new ones
old brakes
new ones
for
I have HiSpec but i am very angry because i bought a hispec kit of 6pots and 330mm disc and with only 1000km and one disc bent and i sent a mail to hispec with the problem 2 months ago and i have not receive answer! The next discs for my car will be AP and the news calipers is ap also!
sorry for hispec this is not a good image for Hispec and his marketing!
for
Graceland
14-09-2009 08:32 PM
EssexBoyRacer
13-06-2006 09:20 AM
