Azev A's on esc cos fitting problems
Old 10-08-2005, 07:05 AM
tim10_10
tim10_10's Avatar
Default Azev A's on esc cos fitting problems
Just purchased a set of Azev A's for my esc cos second hand. Problem is the studs are to short. Do I need longer studs or a sleeve nut which goes deeper inside the wheel. If so any ideas where i can get them thanks Tim.
Old 10-08-2005, 08:11 AM
Glenn5
Glenn5's Avatar
on my m8s car he has sleeved nuts that came with the wheels and he also has longer studs on the front because hes got ap330 brakes and a 3mm shim for clearance you could get longer studs all round and use normal nuts as the avez nuts are poor quality
Old 10-08-2005, 05:25 PM
dave green
dave green's Avatar
I got longer studs on mine and use standard nuts,
Dave
Old 10-08-2005, 05:49 PM
tim10_10
tim10_10's Avatar
ok thanks guys
Old 12-08-2005, 07:57 PM
Chris Honeywell
Chris Honeywell's Avatar
yeah m8 u should have longer nuts with the wheels i did but they are poor quality
Carlbacciochi
24
30-06-2016 04:31 PM
manuel boeckx
13
03-10-2015 02:29 PM
A.t.p
15-08-2015 11:37 AM
Dr. Ickxs
15-08-2015 11:34 AM
cameron2
10-08-2015 12:14 PM
Quick Reply: Azev A's on esc cos fitting problems
