Wot do i need to do to get 300bhp???
Old 09-08-2005, 01:06 PM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
Default Wot do i need to do to get 300bhp???
as above really its a small turbo, ran 298bhp before had parts removed now so need to know how to return it back to that spec really...
i have:-
mongoose
K+N
d/v
hybird T28
just need to know which chip and do i need inj or uprated pump and that really???
cheers Ad
Old 09-08-2005, 06:37 PM
Speedy G.
Speedy G.'s Avatar
A big fat wallet.
Old 09-08-2005, 07:57 PM
adamski frst
that helps i had a dyno sheet from when it did 298 so it should be possible to get it back up to that power??
Old 10-08-2005, 11:48 AM
sailorbob
sailorbob's Avatar
On a small turbo to get that power it's usually a chip, uprated actuator and new fuel pressure regulator.
Old 10-08-2005, 02:17 PM
ryan_belfast
ryan_belfast's Avatar
Graham Goode Stage 2 Chip
Full Exhaust system
Air Filter
Uprated Fuel Pressure regulator
fuel pump
actuator
Old 10-08-2005, 07:23 PM
adamski frst
cheers i have ordered a pump and actuator, gonna get a chip soon i rang msd today and they said nothing bout a new regulator??? what type please guys???
Old 10-08-2005, 07:38 PM
ryan_belfast
Speak to graham goode, say you need an uprated fuel pressure regulator, 4.0 bar regulator i think it is....
Old 10-08-2005, 07:42 PM
ryan_belfast
It should run 1.4 bar too...
Old 10-08-2005, 09:31 PM
adamski frst
we talking the fuel reg runnin 1.4 bar yer??? or the boost???
Old 10-08-2005, 09:50 PM
sailorbob
sailorbob's Avatar
The fuel pressure is upped because the injectors will only flow enough for about 270bhp at standard pressure. I don't think anyone does a chip that works in conjunction with changing the injectors so the fuel pressure regulator needs changing. Check with MSD though if you're getting one of Stu's chips.
Old 10-08-2005, 10:02 PM
adamski frst
yer i rang msd and spoke to kenny he said i'd need a actuator, chip, and setup but no mention of a fuel reg, but i see wot you mean i will get a uprated one anyway where is the best and value for cash???
Old 11-08-2005, 12:03 AM
ryan_belfast
Speak to graham goode, and ask for whatever you need for their 305bhp conversion, now more than likely your car is not going to be 305bhp, prob 280/290 but its close enough for me.
Old 11-08-2005, 08:34 AM
adamski frst
yes thats fine mate thats all i wanted as said i have a power read for 298bhp 320lbft a few yrs bak so it must be possible!!!!
Old 11-08-2005, 09:55 AM
adamski frst
spoke to GGR the want 50 for the reg + delivery there tuning is bit expensie tho for just supplying and fitting the chip and setting up they want Ł700
MSD wanted 520 with a actuator fitted too
Old 11-08-2005, 11:28 AM
ryan_belfast
Get the MSD Chip, email STU on this site, he will tell you everything you need to know.
Old 11-08-2005, 01:17 PM
adamski frst
got the info now cheers bro just need to know where to go to get it done properly i have all parts bar the chip now..
Old 11-08-2005, 02:25 PM
wimwerf
wimwerf's Avatar
on a small turbo escos.....go big turbo route...getting more then 300 bhp on a small turbo is hardly possible with the ford computer....
Old 11-08-2005, 02:28 PM
adamski frst
its ok cause all i want for now is 300 or just under
Old 11-08-2005, 02:54 PM
ryan_belfast
Your the same as me adam, but see once you get used to the 300bhp small turbo, you'll do what im doing and start saving for a big turbo conversion.
Old 11-08-2005, 03:42 PM
Blocos
Blocos's Avatar
http://www.pjmotorsport.com/vehicles...escortcoschips
There is one chip for escort EECIV (T25) 305BHP
But it's very expensive
Old 12-08-2005, 03:20 PM
georgie1
georgie1's Avatar
hi m8 who msd and where abouts are they as im after 300bhp maybe a bit more at mo i got a mongoose exhaust and a k&n cone but been told to take it of and go back to standard i got a standard turbo but i dont know what one to get a t3 or t 34 so need some help please
Old 12-08-2005, 03:46 PM
Blocos
Blocos's Avatar
hi m8 who MSD and where abouts are they as im after 300bhp maybe a bit more at mo i got a mongoose exhaust and a k&n cone but been told to take it of and go back to standard i got a standard turbo but i dont know what one to get a t3 or t 34 so need some help please
+1
Old 12-08-2005, 10:47 PM
sailorbob
sailorbob's Avatar
MSD details are at http://www.remapping.co.uk/
Old 13-08-2005, 09:06 AM
wimwerf
wimwerf's Avatar
if you have a small turbo escos and you want to go big turbo route...then you need a t34......maybe a .48 ex housing...for fast spoolup....or .63 for more top end power..but not that laggy at all....
but im sure some guys on here can help you out..
Marino
12-09-2015 11:10 AM
COLEYST200
03-08-2015 08:55 AM
bigal1978
08-05-2004 08:47 AM
Fiesta RS1800/RS Turbo
08-03-2004 06:38 AM
Quick Reply: Wot do i need to do to get 300bhp???
