What power/torque do you have?
Sorry I meant do my figures read low for a stage 3 ??
I think mine was at peak 23.5 psi and about 21- 22psi held.
Everyone always claims 330 bhp which makes me feel inadequate lol !!!
Its a ahmed bajoo chip, Nobles did say it would benifit from an RS500 intercooler, which i now have so not sure how much difference that will make.
I also have a collins stage 3 chip which I may get fitted next time its on the rollers (think they use a 2.5bar map though) see if that has any vast effect.
I looked at a few cars from some mags which have been roaded at Nobles and they seemed to be a bit lower too ??
Whats the mods on yours for 338 ??
cheers
cheers
Dunno I'll let you know when its mapped by Harvey / Ahmed tommorrow or thursday
cos jon, I have a power Engineering stage III chip for sale in parts section runs greens 3 bar etc, pulled a nice 323brake and 360 torque on my old engne on EA rollers didnt hang about
Damo - Thanks for the offer, funds are a bit low at the mo as MOT and cam belt required very soon. (isn't there always something to pay for!! )
Was that figure and torque with a std T34 what boost ???, very nice torque figure.
The usual greens, 3 map bar, up rated fuel pump and an EA chip. Std turbo.
Damo thats a good torque figure but you were running more boost i think i am 24 psi.
Does anyone know who you need to call or e-mail to find the spec of a collins chip, had mine since i bought the car and was told its a stage 3, just wanted some info on it ??
Are the Ahmed Bajoo chips anygood or are there better ones about ??
1 Post
i heard a rumour years ago that the collins chips used to run more boost hence got more power but at the sacrafice of shortening the engine life, the ahmed ones on the other hand ran a little less boost for more reliabilty, but as i say , his is only what i heard about 5 years back,
Thanks for the info, anything that runs more boost will have an effect on reliability i suppose. When i had mine rolling roaded that said that the ahmed bajoo chips never produced whet they claimed they should. They recommended superchips !!!
Originally Posted by Damo V
im happy with that mate...will suit me fine... i was happy with my old 320
Thats got a massive kick or torque at 2500 - 3000 rpm Goodbye gearbox me thinks
Should feel fapping fast tho, nice one
basic engine spec (from memory)
Big wing sump
Brand new 200 block Longstudded
Genuine WRC headgasket
7.6:1 cr with valve cutouts on pistons
Light blue injectors
T34
MINOR head work
std cams
071 plugs
Dizzyless IGN
pectel board/loom
Big wing sump
T34
MINOR head work
std cams
071 plugs
Dizzyless IGN
pectel board/loom
What power/torque do you have for how many psi?
Hello,
your Turbo is regulated with how much PSI for these powers?
I have a Sierra Cosworth, I have just bought the complete kit stage3 (ECU, map, green, actuator...) and I would like to see how much we can to have with between 15 and 22psi really (dyno tested and not estimated)
Richie Russ, You got a Nick wabbles head though I presume... and cams? I wasnt gonna stretch to that Im afraid
jp184, as you can see from my dyno printout, mine was at 28pound then tailing off to 25/24 psi
.48..... car obviously did have a .63, Harvey specced it with a 48, so swopped em over, his choice, I'll go with his recommendation seeing as he built it and mappped it and knows more than me lol..
My GG 305Conversion T28 Escort Cosworth
Hybrid T28 Turbo
Full Mongoose De-cat System
GG Stage 2 Chip
1.3 Bar Boost
Fuel Pump
Fuel Pressure regulator
243.3BHP At 5422rpm
271.7Lbf/Ft At 3610
BHP is a little low and i dont understand why, he told me this figure was at the flywheel, but i dont see how i can beat the new shape M3's in a race if thats the flywheel figure.
Hybrid T28 Turbo
GG Stage 2 Chip
1.3 Bar Boost
Fuel Pump
243.3BHP At 5422rpm
271.7Lbf/Ft At 3610
260kW (~354hp) @ 5900rpm and 476Nm (~351lbf) @ 4000rpm.
Standard T35 escort engine and turbo. 3" exhaust and bigger cooler, bigger injectors and new engine management. That's just with little tuning which was mostly done by myself driving it along road and adjusting it with wideband lambda. I could have gained more power by adjusting more ignition advance but it was left for the next dyno session. The ignition advance map which I used was pulled out from standard P8 Escorts ecu so the advance was quite mild. The dyno was made by Dyno dynamics (so it should be near the true output).
btw. The exhaust backpressure with that high boost is huge, even with the 63 exhaust. Has somebody measured the exhaust backpressure in UK with ~1.5bar boost? The wastegate clock has to be very tight since the back pressure opens wastegate by itself.
so what box are you going for next?
The reason i ask is that i am at 550 hp and have to get a box. Any tips on this ??
Now i am driving around with no boost to save the box !!
What did you do for driveshafts and cv`s ?
