Intermittent dash light fault
Having a problem that every now and then i turn my lights on and have no dash lights or any side lights, wiggling the swith sumtimes sorts the problem. Is this a comon fault or is it likely to be the fuse board going? Any ideas?
Originally Posted by THE RADMAN
very common prob,you need a new light switch assembly,about £45 ish,i used to tap mine on the end for a temp cure,lol
but the one in the pic does not have the twist switch on the right stalk for the intermittant wiper delay thingy is this the right one???im sure it would all work apart from delay thingy?????
if its raining the car doesnt go out anyway. if it fixes the problem i will be more than happy. i have a estate car as well so it wont go amiss
Dr. Ickxs
15-09-2015 10:15 PM
The Enigma
12-09-2015 10:12 PM
