Adjusting Konis
Old 02-06-2005, 10:51 AM
M.A.D.RST
M.A.D.RST's Avatar
Default Adjusting Konis
Ive got Koni adjustables on my car and have the white adjuster thing, but how do i adjust them?
I know this may sound daft, but the car came with them so havent played around with them. I think the car sits a little too high, especially at the back!
This is my car at central day, does this look like the normal height to you lot?
Old 02-06-2005, 12:33 PM
MONSTER
MONSTER's Avatar
unless you've got coilovers you wont be able to adjust the ride height. All the adjuster does is alter the damping.
Old 02-06-2005, 06:51 PM
marco
marco's Avatar
ride height luks ok 2 me mate
Old 02-06-2005, 09:28 PM
big-dirty-dog
big-dirty-dog's Avatar
looks almost the same as mine which at present has konis fitted 25mm lower springs on the front and the backs are standard one cut to drop down more(it was like this when i brought it)with 25mm lower springs on the back sat way higher than yours looks also running rondells on mine(wanna swap yours for a green un???)
Old 03-06-2005, 03:18 PM
Simbo
Simbo's Avatar
How do you adjust the rear Konis ??
Old 03-06-2005, 05:54 PM
big-dirty-dog
pull down the outer plastic dust cover,theres a small button on the lip push and twist 3 setting if i remember correctly set mine to middle possition and havent moved them since
yatta
21-05-2016 10:31 PM
01-11-2015 06:53 PM
Fezman1
02-10-2015 01:22 PM
IainRS1700T
25-09-2015 06:44 AM
truffleshuffle
10-09-2015 09:35 PM
Quick Reply: Adjusting Konis
