rear spoiler removal
just wondering how to remove the upper rear spoiler as my car is going in for painting and im just removing as many bolt on bits so that it ends up being a proper job. I know there is a bolt securing the top spoiler support underneath the boot cowling. im more worried about the top, is it bolted, bonded etc. i would be greatfull for any help thanks
remove boot trim panel slacken off 8mm bolt then slacken the 4 upper 6mm bolts they shouldnt be bonded on. remove lower bolt can be tight be carefull then with a helper from either side undo the top 4 bolts and gently lift away mite have 2 gently wiggle as years of dirt and polish tend 2 stick them on
