how much boost ?
how much boost ?
how much boost can i run on my small turbo escos ?
it has a 285 superchip, turbo technics hybrid t28, powertec filter, decatted exhaust with centre box removed.. is it advisable to change the fuel pump and regulator with these mods done ?
Thanks
Matt...
Thanks
Matt...
you should change the pump straight away as they are suppose 2 be on there limit as standard m8 let alone chipped, was the first thing i did check with your tuner about fuel reg as aint got a clue mines a big T stg 1 at the moment
Originally Posted by GaryS
Mine holds 18PSI but is running with a Gp A fuel pump. Only set it up last weekend on Autronic wideband lamda gear so I know its safe.
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
