brake issues
Old 08-05-2016, 07:33 PM
ballbag42
ballbag42's Avatar
Default brake issues
eve guys changed my discs and pads and calipers and bleeding the front was ok but the pump didn't want to stop once turning on the ignition changed my rears to larger discs and changed rear hoses no fluid coming to the rear either pumping the pedal or doing what it says in the ford manual surely as it states in the book the rears should be under pressure all ive got is a dribble pumps still going mad anyone had this before ,pump u/s or pressure sensor???
Old 08-05-2016, 07:44 PM
Caddyshack
Caddyshack's Avatar
I think you have got to do rears first and keep going, they can be a bigger, you may need to run it up and drive it on the drive back and forwards then start again. I think you can bleed the master etc too by releasing the threads then nip them up
Old 08-05-2016, 07:52 PM
ballbag42
ballbag42's Avatar
daft bit is the fronts have bleed up fine the rears aren't having any off it even put one of the vacuum bleed units to draw it out but not getting enough to fill the pipe let alone bleed them ive had cossies for years and changed allsorts but never had this before
Old 08-05-2016, 07:54 PM
Caddyshack
Caddyshack's Avatar
Mine are a bit like it. I tend to run the vacuum bleed system and pump the pedal
Old 08-05-2016, 10:31 PM
ballbag42
ballbag42's Avatar
will give it another go when I get 5 cheers
Old 09-05-2016, 11:03 AM
Marc sierra
Marc sierra's Avatar
Did you do anything other than changing the discs and pads? As for discs and pads there is no reason to bleed the brakes afterwards. If the pump keeps running there must be something wrong. It either can't reach the required pressure (bad pump or internal leakage?), or it thinks it can't reach the pressure (broken pressure switch).
Was everything working correctly before you changed the discs and pads?
Old 09-05-2016, 12:51 PM
Caddyshack
Caddyshack's Avatar
I have got spares for all of this if you get stuck, I have pumps, abs blocks, loom, pedal boxes etc.
Old 10-05-2016, 02:34 PM
ballbag42
ballbag42's Avatar
Cheers caddyshack and marcsierra everything was working fine ive changed the fronts from std to 6 pots but they bleed ok the rears i fitted an mt motorsport 300mm kit which reqs changing the flexi brake pipe to the caliper prior to this no probs now pump is going constant and no pressure for fluid coming out of the rears just a dribble
Old 10-05-2016, 02:58 PM
Caddyshack
Caddyshack's Avatar
I doubt it but do the pumps ever have an issue if they cannot flow enough fluid to fill the 6 pots AND the rears...unlikely as once the volume is full then the pressure should be about similar.
If you are in doubt about the pump efficiency you can borrow one of mine to try, it is only one plug and a fitting. I will have the Sealey pressure jobby this week if you get stuck and need a hand. I am not all that far from Gosport.
Old 11-05-2016, 02:31 AM
ballbag42
ballbag42's Avatar
Cheers appreciate that will let you know
Old 12-05-2016, 12:16 PM
Caddyshack
Caddyshack's Avatar
Copied from the other thread: I just used the sealey pressure one and used the Vac on the other end. It was a little slow to start and I have noticed that the rear bleed nipples need to be quite a long way out, not just a nip to undo, I mean a long way out and then the fluid began to flow, I don't have the cossie master but a few pumps and I was turning down the nipple and all was good so top tip....check the bleed nipples are further out than you think necessary!
For £40 you would not be sorry to own the Sealey tool!
jasoft
05-05-2016 06:24 PM
big mikeS
21-04-2016 03:57 PM
joshmils
Ford Focus (All Models)
14-04-2016 04:30 PM
SmudgerByName
11-04-2016 11:24 AM
tockwell
09-04-2016 07:38 PM
Quick Reply: brake issues
