Fitting rs500 cooler
Old 06-04-2005, 05:15 PM
Cossie-Iain
Cossie-Iain's Avatar
Default Fitting rs500 cooler
Ive got a big turbo esc cos with air-con and Ive bought an rs500 cooler plus an alloy rad and the fans as a set off radtec.Has anyone fitted this and does the cooler go in front of the aircon radiator? I tried to take the charge cooler off and both the top nuts broke clean off so im getting the drill and my trusty hammer out once I know how this all fits together.
The radtec stuff is
Old 06-04-2005, 05:18 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Unless Radtec have deleloped something, you will have to lose the air-con...
Old 06-04-2005, 05:31 PM
Cossie-Iain
Yeah this kit is meant to be for cars with air-con on
Old 06-04-2005, 05:58 PM
dave cos4x4
dave cos4x4's Avatar
the air con will have to be removed as you cannot put the i/c on as its in the way.
there is no i/c for air con cars.
Old 06-04-2005, 06:19 PM
M.A.D.RST
M.A.D.RST's Avatar
Oh dear Iain, not having much luck?
Did you get my email
Old 06-04-2005, 08:42 PM
THE RADMAN
THE RADMAN's Avatar
someone else on here fitted this set up, cant remember who it was,the aircon rad sits in front of the intercooler
Old 06-04-2005, 09:46 PM
PAUL V
PAUL V's Avatar
Yes they do a kit with aircon
I would like to know how it fits to
http://www.radtec.co.uk/gallery.php?category=2
Old 07-04-2005, 03:57 PM
Cossie-Iain
This has got to go on with the air-con fitted or im gona
I think its gona fit behind the air-con rad and be a bit of a squeeze but as i say its a complete kit for an esc cos with air-con fitted.Dont know how effective it will be behind A/C rad but its got to be better than standard.
Old 07-04-2005, 08:52 PM
Chris Reade
Chris Reade's Avatar
I'd like to know how this fits and what improvement you get. Please keep us all imformed with photo's as well if possible.
Old 09-04-2005, 12:56 PM
Turbo Chris
Turbo Chris's Avatar
Just ditch the aircon and get more power,lol
Old 09-04-2005, 09:27 PM
Andy f
Andy f's Avatar
Phone radtec and ask them for advice, I fond them to be helpfull in the past.
Old 15-04-2005, 02:54 PM
S3an
S3an's Avatar
what the hell do you need air con in scotland for, its bloody freezing on the best of days. ditch the air con and move to sunny england. problem solved.
Old 15-04-2005, 03:10 PM
Spax
Spax's Avatar
Very True
Old 15-04-2005, 04:59 PM
Cossie-Iain
Yeah but if I take the car to Italy on my holiday it will be needed Im sure
I dont want to rip stuff off incase it effects resale price of car.
Old 01-05-2005, 01:19 PM
Cossie-Iain
Ok Ive put the cooler on the car now and theres plenty of space for the air-con rad but Ive left it off just now.The car was set to peak at 25psi and hold 22psi but since Ive put the cooler on it peaks at 28psi and holds 25psi.Is that normal because I havent adjusted anything?
Old 01-05-2005, 06:18 PM
Dave Henshall
Dave Henshall's Avatar
they do now do 2 versions, the mans version:
and the girls version
Old 02-05-2005, 09:05 AM
Cossie-Iain
Does the job fine for me
Old 02-05-2005, 04:26 PM
ste.w.
ste.w.'s Avatar
Girls version expensive version more like
Old 04-05-2005, 08:28 PM
whitneyd
whitneyd's Avatar
There is a guy in Italy that installs the I/C and then has longer lines made up for the AC to fit. You could try that??
Old 04-05-2005, 08:55 PM
Azrael
Azrael's Avatar
I wonder about fitting large turbo chargecooler with it's own rad and pump to leave aircon alone. What do you think?
Old 05-05-2005, 02:40 PM
Dave Henshall
its actually a good price i suppose as its is a new alloy radiator, intervooler and slimmer fans, i bet if you add the component parts up its not far off a good deal
Old 05-05-2005, 04:56 PM
Cossie-Iain
The deal I got was great.Basically I got the whole kit VAT free so I was over the moon.The A/C rad will go back on no problem.Theres not much room between the fans and the engine pulleys at the front but it all fits.
Old 06-05-2005, 01:23 PM
Mike Rainbird
Caraholic
Does the air-con rad sit in front of the intercooler then? How does that affect the charge temps when the air-con is NOT running (I know how it should affect the temps when it is ).
Old 06-05-2005, 02:26 PM
foreigneRS
Testing the future
foreigneRS's Avatar
not ideal is it? air coming off a\c condenser can be as hot as 70 deg. C
Old 06-05-2005, 02:34 PM
Azrael
Azrael's Avatar
Mike, ForeigneRS isn't it another reason to go chargecooler route?
Old 06-05-2005, 03:05 PM
Mike Rainbird
Caraholic
BT Escorts already have a chargecooler , even when connected to a stand alone water cooling set up (rather than the OE engine coolant method), it is still nowhere near as good as a large air to air intercooler. Would be interesting to see the diff putting the air-con in front makes, as in would it offer no improvement over just a water separation kit?
Old 06-05-2005, 03:07 PM
Azrael
Azrael's Avatar
I know.
Nowhere as good but maybe sufficient?
I hope somebody with such setup will post some ACT's
Old 05-07-2011, 07:40 AM
phs84
phs84's Avatar
i´m fitting this kit now on my "small turbo" escos and the fans are very close to the pulley form the aircon compressor!
and the worst is that the one water-hose that comes out on the left side is very close in front of the aircon pulley!! and there´s no place to fit that hose without touching it!
i don´t know how others solved that problem but i have to consider something about?!
cheers,
philipp
Adam-M
26-08-2015 05:53 PM
TrevCos
Modellers Corner.
24-08-2015 09:31 PM
Dicko&Vacant
21-08-2015 05:59 PM
TIL13R
11
13-08-2015 02:28 PM
Harris.
12
12-08-2015 06:38 AM
Quick Reply: Fitting rs500 cooler
