Escort Cosworth "water boiling"?
Old 29-07-2015, 08:54 PM
midnight_man
midnight_man's Avatar
Default Escort Cosworth "water boiling"?
Hi,
after a normally day driving I turn off the car and I can hear something like "boiling water" comming out of water tank. I think that is comming from turbo water cooling return pipe?..maybe?
Heater tank is under pressure and when I open it...water starts to rising UP.
Head was skimmed, pressure tested, new headgasket.
Any ideas?
Thanks
Old 30-07-2015, 07:07 AM
Caddyshack
Caddyshack's Avatar
Not sure on the fix but you can go Evans prep to remove the water and then Evans waterless as it cannot boil and doesn't expand.
Old 30-07-2015, 12:26 PM
RichieST
RichieST's Avatar
Any other signs of overheating?
Old 30-07-2015, 05:03 PM
Chris Honeywell
Chris Honeywell's Avatar
When i had my Escort a few years ago i had a turbo cooler fitted and had water boiling .
Tuned out the thermostat was stuck shut , exactly that same thing happenning that your are describing.
Old 30-07-2015, 05:24 PM
Mark Shead
Mark Shead's Avatar
Originally Posted by midnight_man
Hi,
Any ideas?
Thanks
If your running temps are fine there is nothing to worry about as the engine is percolating when switched off and do not open cap as this is stopping your water boiling by raising the boiling point due to the pressure the system runs at.
Mark
Vincereese
01-06-2023 09:14 AM
jessie_rs
11
03-06-2019 04:57 PM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Escort Cosworth "water boiling"?
