suspension.............
Which springs give the lowest stance??
Want a set of springs to mate up with koni shocks.
want the car to sit low and level tho!
any suggestions????
any suggestions????
Ive got GGR rear springs with original shocks, not sure if they do front ones though mate, heres what the rear sits like, front end is too high but ive run out of money to get full kit sorted!!
Eibach -25mm
P.I. -25mm
Apex -25mm
Cobra -30mm
Ventura -25mm
GMax -30mm :avoid:
AVO -25mm
ROC -25mm
Bilstein N/A
H&R N/A
Cusco N/A
Let me know if you want a price!!
P.I. -25mm
Apex -25mm
Cobra -30mm
Ventura -25mm
GMax -30mm :avoid:
AVO -25mm
ROC -25mm
Bilstein N/A
H&R N/A
Cusco N/A
Why has cobra got a differant face???
Give me a price on Eibach and cobra?
Do you do chassis dynamics? i believe these are -30mm?
Could do with -25 front and -30 rear, would make a bit more of a level stance???
Originally Posted by bigpower
Why has cobra got a differant face??? BIT LOWER MEANS DOUBLE COOL FACE!!!
Do you do chassis dynamics? i believe these are -30mm? CHASSIS DYNAMICS IS AVO
Could do with -25 front and -30 rear, would make a bit more of a level stance??? ANY -MM FIGURES QUOTED ARE APPROXIMATE AND TBH MOST ESC COSWORTHS I'VE DONE SIT WELL ON EQUAL HEIGHT SPRINGS....25/25, 30/30, 40/40 ETC ETC BUT IF YOU 25/30 I CAN MIX AND MATCH.
PM SENT
PM SENT
