Escort Cosworth Idle Problems
24-02-2015, 07:41 PM
Green Bosch 803
Marelli 3 bar Map
MSD Chip
Mongoose Decat
-34 Rated T3 Fitment Wastegate Actuator
What could cause this drop down in A/R ratio when idle drops down? I did nothing with the gas paddle!!
24-02-2015, 08:57 PM
Mine did the same thing and it had a leak on the plenum gasket
25-02-2015, 06:07 AM
06-03-2015, 01:04 AM
Could be the Lambda Sensor.
I had similar problems and it turned out to be this.
06-03-2015, 01:38 PM
Make sure the P8 has had a reset done,
Check and adjust the base idle with the ISCV disconnected,
check the ECU voltage is stable, and check the lambda function as mentioned as a starting point.
Vincereese
01-06-2023 09:14 AM
jessie_rs
11
03-06-2019 04:57 PM
James Porter
26-08-2015 10:51 PM
Vincereese
16-08-2015 06:38 PM
Old ford
31-07-2015 06:50 AM
