no fuel pump prime escos????????
R9 in fuse box.
U can use 2 male plate connectors and piece of wire to bypass it (on the large slots)
No need to switch on, you plug it should run!
If not, the common pb is the welding inside the fuse box.
If it run you should check the inertia switch and then the ECU and its loom.
(Well... I'm not sure if the inertia switch is on the relay command or power so check it anyway (it should be on command))
JK12
33
26-04-2021 12:09 PM
DixieTheKid
11
06-06-2020 11:20 AM
