Help: brake pressure accumulator
Hi guys,
I wanted to ask where I can get the brake accumulator? I saw many on the ebay. What is the pressure I need (psi)? Are all cossie uses the same thing?
I have just removed a Sierra 4x4 one if they are the same.
I would talk to Burtons or Ford and then if not I guess any of the "big" names in the Cossie Schene may know if and where to get them from.
I suspect that the best you will do if find a good second hand one and maybe have it stripped and refurbed?
Did you find one? Mine is available
