Doing away with air injectors
Old 14-10-2014, 07:35 AM
Zook
Zook's Avatar
Default Doing away with air injectors
Hi
Is it possible to do away with the air injector set-up and go external gate with an electronic boost controller if an aftermarket ECU is used?
Thanks
Old 14-10-2014, 09:08 AM
jontysafe
jontysafe's Avatar
Yes.
But depending on the ecu features you may not need an external electronic boost controller. You can just use a solenoid run by a mappable signal from the ecu.
What ecu you looking at?
Old 14-10-2014, 12:18 PM
Zook
Zook's Avatar
Originally Posted by jontysafe
Yes.
Thanks for the reply. I haven't quite yet decided but was just curious to know if it was possible. Good point about the running the boost control via the ECU as opposed to a stand alone, I will have to factor this in when deciding on ECU
Old 14-10-2014, 12:44 PM
jontysafe
jontysafe's Avatar
I run an apexi avcr on my Westie because it gives me boost mappable to gear, rpm, road speed or throttle position.
Internal gate Gt3076 and still running L8 at the mo.
Only downside is the ecu cannot dial down boost when other conditions are out of certain parameters such as air charge temp, knock etc. your Weber-marelli ecu controlled air injectors are actually safer than an electronic boost controller for that reason.
That said the avcr is a great piece of kit and controls boost perfectly.
If I go standalone ecu I may still use it but build in over riding safety features.
Edited to add:
If I had of had these safeties built in previously I wouldn't be rebuilding a melted pistoned engine now!
Old 14-10-2014, 03:31 PM
Mark Shead
Mark Shead's Avatar
Edited to add:
Unless you are running closed loop wideband also the likelihood is it would have still melted as yours would have been a lean melt.
Mark
Old 14-10-2014, 04:16 PM
jontysafe
jontysafe's Avatar
Hi Mark, do many of your builds use closed loop wideband fuelling control or do you rely on safety margins on mapping boost, ignition and fuelling.
Old 14-10-2014, 06:39 PM
Mark Shead
Mark Shead's Avatar
Most don't as its a cost option due to the fitting costs and parts, Correctly speccing everything will avoid problems.
Mark
mk3ste
17-10-2021 10:09 AM
Brickhouse
14
03-10-2015 07:28 PM
Johnny Knoxville
30-09-2015 07:21 AM
stevecfrst1
30-09-2015 05:18 AM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: Doing away with air injectors
