help required engine wont rev past 1000RPM
ENGINE WAS RUNNING PERFECT FOR 3 MILES THEN
IT SUDDERNLY STARTED TO PLAY UP AND NOT REV PAST 1200RPM
HAD A LOOK NO PIPE OFF AND TICK OVER IS SPOT ON
ANY IDEAS
ANY IDEAS
Update is that picked car up from were I left it and drove home perfectly
But by the time I got home it started to play up again so it's temp related but what I'm under sure
Some say blue temp sensor on back of head to change first ?
Yeah back of the head above the brass dash temp sensor.
The ecu reads engine temps through the blue one. If its giving the ecu the wrong info it may be faulty.
Worth a try, but I don't think it will cure it. They either work or don't.
Check all of the jpt connectors on the engine sensors, you may have a broken wire
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
borboyous
22-08-2015 11:17 AM
JoeyBoyden
18-08-2015 05:56 PM
