Escort rs cosworth ecu p8
Old 06-01-2014, 03:07 PM
mpales
mpales's Avatar
Default Escort rs cosworth ecu p8
Recently i bought an escort rs cosworth and i want to check my ecu if it is santadard or it has a chip????is it possible someone to upload some photos with p8 ecu standard chip
Old 06-01-2014, 03:21 PM
mpales
mpales's Avatar
i open the ecu
[img=http://s14.postimg.org/vrgo6hoo1/tttt_046.jpg]
print screen
is it original chip???my ecu is p8
Old 06-01-2014, 03:23 PM
mpales
mpales's Avatar
print screen
Old 07-01-2014, 10:09 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
You would never be sure without the sticker on the chip.
what is it you require? You can remove the chip and send it to me i can tell you what it is.
(FOR FREE BEFORE MODS START)
Old 07-01-2014, 11:21 AM
oldford
oldford's Avatar
This chip is NOT standard - the contents may or may not be standard.
The standard chip has the addtion F6, not F1.
The addition F6 means an industrial chip, guaranteed up to minus 40 degrees Celsius, where F1 means a commercial chip, only guaranteed above 0 (zero) degrees Celsius.
You could get all kinds of weird problems in the winter when it is freezing.
Old 07-01-2014, 03:24 PM
mpales
mpales's Avatar
So I must find a normal chip..or a complete ecu p8 with standard "chip"..anyone has for sale???
Old 08-01-2014, 07:19 AM
oldford
oldford's Avatar
Any competent tuner should be able to sell you a "standard" chip.
Although I have seen some "tuners" use commercial chips like in your ecu.
The big question is: will the engine run on the standard chip?
Or do some parts need to be changed to make the engine standard again - like map sensor or injectors.
Old 08-01-2014, 03:18 PM
costina
Live long and prosper!!
costina's Avatar
www.bigturbo.co.uk
Vincereese
01-06-2023 09:14 AM
Vincereese
18-08-2015 03:57 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Escort rs cosworth ecu p8
