Are COSY and ANTI ecu's interchangable
As per the title anyone know if you can put a COSY ecu into a car that has an ANTI ecu? Are they interchangable? Might have an issue with my ANTI ecu but don't want to spend money on a COSY one if it won't work.
Thanks.
John.
Thanks.
John.
The small turbo cossie ecu's have a 4 letter code, the ones i know of are CARD, COSY and ANTI, i believe they're just software updates but i don't want to spend 200 quid on a COSY coded ECU if it won't work with my car
John.
John.
eeciv ecu's are interchangable i'm sure
i have swapped them in the past and never had any probs, unless i've just been lucky
Hi Jamie,
You've definitely swapped different ones, they've had the different codes on the ecu sticker?
Just double checking before i spend the cash
John.
John.
