no spark
no spark
Hi I just fitted new engine to my esc cos and now has no spark. If i put a plug in one of the leads you get a small spark when you turn on and off the ignition but nothing while cranking. pump doesn't prime unless I unplug the blue sensor on passage side of block the pump will prime but as soon as I plug it back in it stops. running out of idea's now
Led diagnostic?
Or check all wires from sensors to ECU ( distributor cap and crank pulley )
Do you have power on injectors while starting? (use small light bulb for test)
DixieTheKid
11
06-06-2020 11:20 AM
deathrider666
28-09-2015 06:12 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
