Cosworth TDC crank sensor help
I brought all new sensors from MSD all went in fine except the TDC sensor.
I've tried to gap it but with max adjustment still is more than 1mm, tried the old sensor and that's the same too
Any suggestions??
Any suggestions??
Sensor bracket issue
I just got a TDC sensor bracket from a UK supplier and when I installed it the centre of the sensor was about a quarter inch forward of the pulley mark. I have a 4x4 block and a 2wd crank case/sump. Are there different sensor brackets? If so where can I source the correct one?
