How do you change the front diff oil - help !
Hi, anybody know how you change the front diff oil and if you need a new gasket or sealant ? Had a look with it jacked up but couldn't see an obvious drain plug ?
Thanks
Thanks
You don't have a drain plug, loosen all the lower cover bolts , remove it, clean it , seal it , tighten it and fill from the filling plug that you have on the side. Hope this helps you !!
ekjim
17-08-2015 08:57 PM
st220kyle
16
14-08-2015 06:13 AM
track.focus'd
12-08-2015 05:53 PM
