| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Cosworth This forum is for discussion of all things pertaining to the Ford Escort Rs Cosworth. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
Make sure the alternator isent draining the battery.
put a good battery on the car leave it for an hour then touch the alernator it should be cold if its warm the alternator has a fault. Got to start somewear,
__________________
#3 |
All fixed ! Thanks for the help lads, problem fixed. Had a look at the fusebox, it's in good nick (for a Mk 5 !) and the voltage was charging when tested across the battery. People who had the car for the last 6 weeks blew a fuse and replaced it with a duff one, it looked to be fine but i suppose i should have replaced them all as a matter of course. Just out of interest, the fuse for the brake lights also provides the feed for the dash lights and power to the gauges and warning lights. Apparently the warning light circuit for the battery is used by the alternator to provide a small charge which is used to monitor battery state and operate the charging function on the alternator. But because the warning lights weren't working (duff fuse!), the alternator decides not to charge. Suppose i'll shut up now i've waffled on a bit.
Thanks again guys cossie
#4 |
i have the same problem on my sierra saph cossie i turn the key no dash abs light no ignison lights the car starts okay i also have no rev counter or temp gauge but my fuel gauge works i turn on the lights the dash lights up what can be the problem can ayone help me
| Display Modes | |
