2.1zvh t cosworth L6 management ..fuel pump runs constantly b4 starting..??
2.1 zvh turbo with cosworth L6 management ..
Hi guys ive got a really strange one here ..for some reason my fuel pump has started running constantly when ignition is on before starting ..and very weirdly wont go in gear when this happens the other day I put a new ecu relay in and that cured it and it would go in gear fine ..But I went to go on a test drive i barely got off the drive and it cutout completely no ignitiion lights at all I found that the yellow 60amp fuse had blown
So fitted new one but now have same problem again fuel pump constantly runs and car wont go in gear when this happens it also causes the fuel regualater to screem ..ive even dissconnected the cps sensor stil no difference.. Its strange cos I had a problem with
The lights which caused a relay on the fuse board to go since then ive had this problem..??
big_Rad
15-09-2017 09:36 AM
Cameron
14
09-08-2015 06:28 AM
