EEC IV 295 Chip
18-07-2012, 07:19 PM
EEC IV 295 Chip
Anyone have experience of these? Any issues etc.
Just seems like a lot of power for stock injectors/turbo etc, I'm not convinced (but I'm prepared to be enlightened)
19-07-2012, 05:32 PM
Yeah they work well, chip, -31, and ideally an ITP048 fuel pump and a nice set of plugs.
19-07-2012, 05:41 PM
Quote:
Originally Posted by
James @ M Developments.
Is that a replacement internal tank pump? A dash 31 scares me, it can be seen. The cars factory fresh would hate for an aftermarket actuator to stand out
19-07-2012, 05:54 PM
our -31s look the same as the factory items, only cleaner
the pump is in tank yes.
All the bits you need are on our webshop
http://www.shop.motorsport-developme...worth-18-c.asp
23-07-2012, 07:03 PM
You've never seen my engine bay
Will have a look and give it some serious consideration. Once the palpitations over non-standard parts have stopped.
23-07-2012, 07:18 PM
aka Turbosailorboy
Location: Under the water.... .......in a nuclear submarine
James, is this a simple fit/set up or does it need a trip to MSD?
24-07-2012, 08:23 AM
Can be done DIY if you have the gear for fuelling checks etc.
25-07-2012, 10:56 AM
Is this chip really 295bhp? are these better then the superchips one?
30-07-2012, 06:42 PM
The superchips ones ive seen run very lean at higher rpm, infact most run richer with the chip removed
02-08-2012, 09:13 AM
Ok so i will look to buy one off you do you have some deals on thee lol!
02-08-2012, 10:09 AM
If you email steve your spec, im sure he can help you out as a regular customer.
02-08-2012, 07:12 PM
I will contact hij tommorow about this! Thanks james!
Mile30
69
13-05-2017 08:44 PM
tankybaby66
06-02-2016 02:24 PM
STAFFY OWNER
18
21-09-2015 02:50 PM
RSmark84
13-09-2015 01:29 PM
