tuning a escos t25? suggestions please????
hi basically im looking into tuning my escos the car is running all standard management but at the moment has a stage 1 chip rs500 big intercooler uprated fuel pump airfilter full decated staineless t3 hybrid turbo i also stripped the engine right down all new gaskets group a head gasket so engines good for little more power run her up the quarter mile and run a 13.3 at 100mph not bad for 14psi boost so want to run 350ish bhp and high 12s quarter mile whats your suggestions??
Hi yeah this is what I was thinking i need to find Someone who has done this and can make me a list of what's needed to do this I'm mechanic and had my cossie apart to many times but wires ain't my strong point inless I have it in black and white in stuck.
https://passionford.com/forum/ford-e...-cossie-5.html
my small turbo cossie runs on haltech ps 1000 and t35.63!
You can map them to have over 300bhp. My friends had his mapped at NMS on a hybrid T28 and it was over 300bhp. Pretty sure Turbosystems and MSD can map EECIV too. MSD was developing a T34 conversion for them a while back.
I like the sound of sierra or earlie escos management due to owning a sierra which was dirt cheap and very easy to tune! One of my friends runs a after market management and is having quite a few problems think its a omex
No don't have donor car but was looking my t3 will handle 350 so will only need engine loom Ecu injectors map sensor throttle body and couple of small sensor looking around Ł500 for good second hand
with an aftermarket ecu you can do anything you want and you use the "better" htt inlet manifold.
mine is about 360 at the moment and i´ve no probs with it.
SMILER258
28-09-2015 09:04 AM
Si B
12-09-2015 06:49 AM
