is this a cossie block ?
Does anyone know if this is a genuine cosworth block ?
And anything about its possible history.
Markings on block are.
35 020
205
/ 85hm6915B-B
It has YBB5884 stamped on front of block, no engine number.
35 020
205
/ 85hm6915B-B
Thanks for the info.
The ad hints that it might be an RS500 block, I think they were claimed to have smaller welsh plug holes and were a heavier , at least some were (the race ones), not sure if the block numbers are any confirmation one way or the other.
Hi Mike,
Yes we have been quiet on here for a while, Linc is very busy at work... I am busy too but recently I have been getting into the car again. I will have to post some pics for you, I have been just sending them to Linc direct to keep him interested ( he was in Germany recently)... We did some interesting comparisons on flow benchs of his head versus mine.
Next step is to get those long studs you supplied put in, finding a decent engineering shop is the challenge... as I want the bottom end done as well as you would expect.
Drop us a line on where you are up to
Gavan
Gavan
I wonder if this was used by DJR the year before RS500 cam out. It looks like one of his, that water pump is pretty much what he had...
Unfortunately when I chatted to the guy the block has had all the cosworth crank and rods replaced with std pinto gear...
Thanks for the help guys
Caraholic
Hi Mike,
Gavan
Gavan
Just enjoying using the car at the moment, so nothing happening mod wise at present (see my You Tube vids ).
