Bleeding brakes
Bleeding brakes
Hi all
I'm having new discs and pads on the front of my car and having new rear discs, pads and calipers.
Is there a order to bleed the brakes when we have finished, the car will be on a 4 post lift or can put on a ramp lift if they need bleeding with load on the axles.
Thanks for any help
Dan
Thanks for any help
Dan
Thanks for the reply.
Dan
Edit updated pic
As said, also when refitted apply the foot brake vigorously several times before applying the handbrake, otherwise it won't work properly.
I always start furthest away from the M/C and work my way in, i.e. the nearside rear first, then offside rear etc.
Martin
Martin
