cdf drop links
Old 01-07-2011, 07:01 PM
Phil2002
Phil2002's Avatar
Default cdf drop links
i have a set of cdf racing drop links and i can not for the life of me get them to fit
I have already fucked one set of bushes trying to get them on and not far off doing the same again.
Has anyone actually fitted these with any success.
thanks,
Phil
Old 02-07-2011, 12:54 PM
STUCOS
STUCOS's Avatar
Phil had the same problem mate,ended up fuking them across the garage and fitting a new standard set
cheeRS stu
Old 02-07-2011, 12:59 PM
Miller 3
Miller 3's Avatar
Phil above has now fitted them, you just need to make sure that all the surfaces are smooth and clean, it is also worth putting the polly bush's in boiling hot water to soften them up, and apply a liberal coat of copper grease when fitting.
Old 08-07-2011, 03:27 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
The biggest issue we find, is that the original mounting pins are corroded to hell and actually bigger than they should be and courser too, so need a damn good cleaning to get them on!
Old 21-12-2011, 09:40 AM
Sonic Boom
Sonic Boom's Avatar
I tried fitting mine yesterday all my rear beam and rear arb and minty clean and I still couldn't get them to go over even with loads of hot water and fairy liquid (other washing up liquids are available) and now the poly bushes are fucked!
Rich
Old 21-12-2011, 10:23 AM
Phil2002
Phil2002's Avatar
Rich
This what happened to mine mate i got a set of new poly bushes from MSD.
The lugs that the drop links mount to on the arms and the ARB i grinded and filed the raised section off then drilled and tapped an M6 thread into the end of each lug. I then managed to press the drop links on and bolt a large stainless washer to the end of the lug to prevent the drop link from sliding off.
Phil
Old 21-12-2011, 10:25 AM
Phil2002
Phil2002's Avatar
I'll get some pics of them fitted at some point and post on here.
Phil
Old 21-12-2011, 10:30 AM
P412KER
P412KER's Avatar
Eventually got mine on after alot of f**king about, used a set of mole grips in end.
Only problem is is that they are all marked off the molegrips and look a bit shit now..
Old 21-12-2011, 10:39 AM
James @ M Developments.
James @ M Developments.'s Avatar
if they are really tight, can you not just drill the bush slightly?
The ones ive fitted have been tight, but not to the point they wont fit, They do need to be a tight fit.
we keep the bushes here if you need some.
If there is a real problem here i will ask CDF to look into it as we were not involved in the design of these.
Old 21-12-2011, 11:14 AM
Phil2002
Phil2002's Avatar
The main problem i had was that once there loads of lube on there the bushed pushed them selves out the drop link. used sockets, vice and moles grips etc but still no joy so decided to do what i explained above.
@James - Did think of drilling the bush but decided against it because i didn't want it to be loose and wanted them to be a tight fit like you said above. I think the issue is due to raised section of the mounting lug being to large for the bush to push over.
Phil
Old 21-12-2011, 12:07 PM
Yes i see what you mean, maybe doing what you did, and if needed even drilling and adding a washer and split pin to the ARB to prevent it comming off will work.
Old 21-12-2011, 06:48 PM
Sonic Boom
Sonic Boom's Avatar
Phil
Yep exactly what happen to me, I tried using a socket and it just cut it's way into the bush
James how much is a set of bushes for the drop links?
Or do you give them away free for the grief?
Eich
Old 12-01-2012, 09:11 AM
We don't make them mate, or design them.
we do the bushes separate. Ł19.99 for 4.
Old 12-01-2012, 09:32 AM
busa bob
busa bob's Avatar
If your going to go to the extent of grinding, drilling and tapping you may as well fit rose jointed drop links as i have.. They are only Ł45 and a doddle to fit.
Look better too imo
Old 12-01-2012, 09:40 AM
Sonic Boom
Sonic Boom's Avatar
You also do 2 for Ł9.99 as I ordered them the otherday, the 2 bushes that go onto the arb I drilled out to 10mm from 8mm and left the ones that go onto the beam as is, it was still hard as fuck but finally got them on.
I think I know where the problem lies thou, the oem bushes are concave both sides so it slides in easier then as it goes through locks/holds tight on the otherside I don't think this would be a hard fix just a slight redesign of the bush to something like this;
I'm no Solid Works/CAD type designer so i quickly knocked this up on Paint but i think you'll get the idea:
Rich
Old 12-01-2012, 09:42 AM
Sonic Boom
Sonic Boom's Avatar
Look better too imo
If I hadn't just had everything powder coated that's exactly what I would have done.
Rich
Old 09-02-2012, 08:49 PM
Toe Knee
Toe Knee's Avatar
any pics of the drop links fitted and ideas where to get them?!
Old 10-02-2012, 12:55 PM
Phil2002
Phil2002's Avatar
Motorsport developments sell the billet cdf ones i'll see if i can get a pick up for you this weekend.
Phil
Old 10-02-2012, 08:14 PM
Toe Knee
Toe Knee's Avatar
Sorry mate dunno why i said drop links i meant to say rose joints!!!
Old 10-02-2012, 08:33 PM
dojj
Resident Wrestling Legend
dojj's Avatar
can't you just pop the bushes on first and then slide the drop links over the top of them?
Old 11-02-2012, 03:38 PM
Sonic Boom
Sonic Boom's Avatar
Unfortunatley not that's one of the many things I tried.
Rich
Old 11-02-2012, 05:34 PM
dojj
dojj's Avatar
have the redesigned bushes been easier to fit then?
Old 11-02-2012, 05:50 PM
damien roe
damien roe's Avatar
i have a set of flo flex drop links and where easy as fook to fit
Old 12-02-2012, 08:18 AM
onslack
onslack's Avatar
I've also bought some these cdf drop links, even after heating them up and using fair liquid mine haven't got a hope in hell of going on, neither my beam or my arb are corroded!
I also bought an msd diff mount and both the bolts were too long and needed at least 1cm taking off!
I thought the idea of these was to buy and fit not buy,modify and then fit?!
Old 12-02-2012, 01:19 PM
boost mad
boost mad's Avatar
Link please. I dont want to buy something that i have to modify to fit when its sold as a direct replacement
Old 12-02-2012, 04:47 PM
Phil2002
Phil2002's Avatar
flo flex are exactly the same as the cdf one's. flo flex made the bushes
Old 12-02-2012, 05:43 PM
Sonic Boom
Sonic Boom's Avatar
That was just my suggestion and quick knock up in paint they haven't actually been made.
Rich
Old 12-02-2012, 05:54 PM
dojj
dojj's Avatar
ah right
so is it just that the holes in the bushes are simply too small to fit over the lugs then?
if so, how were they tested?
i think it's probably the original hole size spec'd for the standard drop link when made in poly simply won't flex as much to go over the top, whenever i fitted my standard drop links i always used a g-clamp to wind them back on again
Old 12-02-2012, 06:18 PM
damien roe
damien roe's Avatar
the bushes in my drop links look fook all like the drawing above they might be made by the same company but the design is differant
Old 12-02-2012, 06:23 PM
damien roe
damien roe's Avatar
i can't find them
email flo flex
Old 12-02-2012, 06:26 PM
damien roe
damien roe's Avatar
a pic for you's
i had them on in 5min and not one bit of blood lost
Old 13-02-2012, 08:49 AM
onslack
onslack's Avatar
god only knows how you managed too get them on,mine wouldnt budge at all
i need to eat more spinach!
Old 13-02-2012, 11:05 AM
DAN-Saff
DAN-Saff's Avatar
My customer had the same problem with the diff mount and typically he was told his was a one off and they've fitted loads without a problem lol
They're made by compbrake so I suppose that's why lol!
Old 13-02-2012, 11:21 AM
boost mad
boost mad's Avatar
I thought they were made buy CDF ?
If they are made by Compbrake, after the stories ive heard about them , i wont be buying any more parts like this from them
Old 13-02-2012, 11:39 AM
DAN-Saff
DAN-Saff's Avatar
The diff mount is the same as the pic in the comp catalogue. The drop links are made by cdf.
Old 13-02-2012, 11:40 AM
Phil2002
Phil2002's Avatar
They are made by CDF.
Old 13-02-2012, 11:53 AM
Sonic Boom
Sonic Boom's Avatar
The diff mounts are made by CompBrake they have their name engraved into them.
Rich
Old 13-02-2012, 12:07 PM
Phil2002
Phil2002's Avatar
Rich
They even look shit imho.
Old 13-02-2012, 12:54 PM
onslack
onslack's Avatar
Rich
i must of been blind as i never saw any engraving on mine
Old 13-02-2012, 01:10 PM
Sonic Boom
Sonic Boom's Avatar
It's definatley got CompBrake engraved on mine I can take a photo if you like?
Rich
Quick Reply: cdf drop links
