bronze or steel valve guides??
Old 12-04-2011, 01:17 AM
liamford
liamford's Avatar
Default bronze or steel valve guides??
hi guy,
having the head off my small turbo cossie due to a bit of smoking, so changing the valve stem seals (after new turbo and breather fitted already fitted), just wondering is it worth changing the guides? if so what ones? burton power doing a set of 16 steel ones for around £38? or do you think the bronze ones are better? im not sure...
cheers guys liam
Old 30-06-2011, 11:30 PM
Karl
Norris Motorsport
Karl's Avatar
Hi,
As standard the small turbo head has cast iron guides, and unless they are worn, they do not require replacement. If they are worn you can use either the original cast iron items OR the earlier bronze guides. (Don't forget the bronze guides have a C clip that wont be fitted to the cast iron items you remove so will need to be purchased along with your new bronze guides)
Old 01-07-2011, 11:20 AM
cozmeister
More boost Igor!
cozmeister's Avatar
Can the cast iron guides be used in early model heads in place of the bronze guides?
Old 05-07-2011, 10:26 AM
Guide wear is a chronic problem on cossies, the best material is COLSHIBO, expensive but only ever done once, this is what I use.
Old 05-07-2011, 11:00 AM
OldDan
OldDan's Avatar
Why is it that a google search on your material "COLSHIBO" only brings up three results, the three of which are your posts on passionford?
Old 05-07-2011, 11:12 AM
Chip
*** Sierra RS Custard ***
Chip's Avatar
Cause he made it up or spelt it wrong I guess
Old 05-07-2011, 12:24 PM
sailorbob
sailorbob's Avatar
Colsibro. It is an excellent guide material.
Old 05-07-2011, 12:33 PM
Chip
Chip's Avatar
Spelling error then.
Old 05-07-2011, 01:20 PM
OldDan
OldDan's Avatar
Was kicking my head in trying to find it, google kept trying to rename it to some japanese dragon!
Old 05-07-2011, 02:55 PM
I must have misheard, or made it up, but it's the daddies stuff apparently!!
Old 05-07-2011, 03:05 PM
chaffe
Turbocharging Technician
chaffe's Avatar
fpmsl
Old 05-07-2011, 03:52 PM
Rob_DOHC
Rob_DOHC's Avatar
After speaking to the cylinder head shop in Surrey their opinion was that iron guides were much harder wearing than bronze, I chose cast guides because a) im tight and b) they are cut down and smoothed into the port so the loads on the guide will be higher combined with the faster wearing bronze might mean my lazy arse would have to change them more often.
They also sell what they call nucleous power guides, they make these from Colsibro, which they describe as being a copper-nickel-silicon alloy. If i was doing it again i would probably use them. Seems Colsibro is used in aviation engines a lot.
They also list a material called Trojan(?) which is even better than Colsibro.
http://cylinderheadshop.com/nucleus-...-power-guides/
Rob,
Old 05-07-2011, 04:25 PM
Chip
Chip's Avatar
Dont forget that harder wearing guides tends to mean more damage to valves, especially if they are non standard valves.
So for example if you have titanium valves you would want something softer for the guides so the valves dont wear out.
There isnt really an answer that applies to all applications.
So i would take Karl's advice about this specific application as its clearly one that he knows a lot about.
01-11-2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
17-10-2015 10:32 PM
07-10-2015 12:56 PM
little bram
27-09-2015 07:45 AM
Quick Reply: bronze or steel valve guides??
