TPS for P8
TPS for P8
hi guys ....
I have a problem with a chip, I think it can be this bad TPS. need text, but I've seen that has various positions (1 cm up / down).
resistance varies according to the position, as should be all right?
few (volt / ohm) must have?
thanks
thanks
Idle position is self-learning (within limits) so a small variation has no effect.
Set idle position to 0.15 to 0.20 volt.
Check full throttle signal, should be at least 4.5 volt.
DixieTheKid
11
06-06-2020 11:20 AM
kosienutter
31
22-08-2015 09:55 AM
