engine timing procedure ?
Old 07-01-2011, 10:27 PM
liamford
liamford's Avatar
Default engine timing procedure ?
hi guys
im taking the head of my small turbo cossie to change the valve stem seals, but im not to sure on the setting of the timing set up? when the head goes back on.
Any help would be much appriciated.
thanks liam
Old 09-01-2011, 06:53 PM
cozzy jeff
cozzy jeff's Avatar
time it up like this before you remove you head,then make sure they go back the same way.
Old 02-02-2011, 01:24 AM
gog
gog's Avatar
Hi Liam, have a Cosworth Manual if you want to borrow it? also a crank pulley puller!
Let me know,
Regards
Gog
Old 03-03-2011, 10:16 PM
liamford
liamford's Avatar
hi gog, i have decided to get my mate to do the job, to busy with work at the min...thanks for the offer tho mate !
RUBY123
22-10-2023 12:04 PM
Bailes1992
16-08-2015 07:14 PM
Rickyrustyfox
13-08-2015 01:11 PM
taylora1409
12-08-2015 12:06 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: engine timing procedure ?
