Gearbox rattle
Old 14-10-2010, 07:41 PM
robbob
robbob's Avatar
Default Gearbox rattle
Evening all having some problems with my new cosworth,when i bought the car a couple of weeks ago the bloke told me it needed a new clutch release bearing,as ther was a loud rattle but goes when the clutch is pressed,so i replaced this but the rattle is still ther but goes when you push the clutch,eny body have eny ideas cheers.
Old 14-10-2010, 08:48 PM
NEIL A
NEIL A's Avatar
What clutch are you running some uprated clutches do have a slight noise from them.
Old 14-10-2010, 09:03 PM
robbob
robbob's Avatar
Just a standard one mate,and its quite a loud rattle.
Old 15-10-2010, 05:39 AM
grcossie
grcossie's Avatar
Is it a standar gearbox?
Old 16-10-2010, 11:32 AM
Dearo
Dearo's Avatar
Have you checked the oil level ??
Old 16-10-2010, 12:06 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
if its there with the clutch realeased then its more than likely the gearbox as the input sharft will be spinning with the engine so the noise is comeing from a bearing inside the gearbox
Old 16-10-2010, 01:52 PM
Cossy Mike
Cossy Mike's Avatar
Input shaft bearing, mines exactly the same.
Take gearbox out and the main input shaft will rattle about slightly.
When you press the clutch in, it keeps it tight, therefore does'nt rattle.
Everyone says it's the release bearing, only if your very lucky!
Old 17-10-2010, 04:14 AM
NEIL A
NEIL A's Avatar
Have heard of the chain in the transfer box making a noise aswell if its stretched, but couldnt say if this goes away with the clutch being dipped.
Old 17-10-2010, 05:46 PM
robbob
robbob's Avatar
Right so new gearbox time,has eny one got one they could sell me cheers rob.
Old 17-10-2010, 06:55 PM
Cossy Mike
Cossy Mike's Avatar
Input shaft bearing is Ł22, I fail to see how you would need a second hand gearbox
You'll be buying some else's problems.
If you get a decent company to do it, I was qouted Ł200 to strip all the internals out and replace ALL bearings and oil seals.
Old 17-10-2010, 07:46 PM
robbob
robbob's Avatar
That sounds better mate,who was that wid,realy need it sorting.
Old 18-10-2010, 04:30 AM
Cossy Mike
Cossy Mike's Avatar
Try G R S Gearbox specialists, there based in Newburn/Newcastle or there's Keldine near the Metrocentre, bit more expensive though.
chowfornow
14
05-01-2019 09:01 PM
mjonathan24
29-10-2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
17-10-2015 10:32 PM
Iain Mac
30-09-2015 09:39 PM
Fudgey
17-09-2015 01:06 PM
Quick Reply: Gearbox rattle
