PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Cosworth
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 08-04-2010, 07:19 PM   #1
liamford
Trader Score: (0)
liamford is an unknown quantity at this point
Default clutch cable adjustment?
hi guys, i have a problem with selecting a gear sometimes, its real hard to push in to gear...only sometimes tho, the clutch was changed about 5000 miles ago, if you push the pedal all the way down and select a gear, you hardly have to lift your foot and it starts to bite, could it be that the cable has stretched? is the an adjustment or would i need to buy a new cable?
its on a 96 st escos thanks
liamford is offline   Reply With Quote
Old 08-04-2010, 07:48 PM   #2
grcossie
grcossie's Avatar
Trader Score: (0)
grcossie is an unknown quantity at this point
It`s a self adjuster under the pedal, this is made of plastic, and the theeth can get worn. Sometime it helps, to lift the pedal, and pull the plastic half moone down, then you push the pedal a few times. If you hear some click, then it has adjust a bit
__________________
Sierra saphire 88 2wd Cosworth stg1
Escort Cosworth 93 stg3
grcossie is offline   Reply With Quote
Old 08-04-2010, 08:11 PM   #3
liamford
Trader Score: (0)
ill give a try cheers, if it doesnt work im lloking at a new cable is it?
Old 08-04-2010, 08:18 PM   #4
grcossie
grcossie's Avatar
Trader Score: (0)
It could be, but check that the self adjuster dosen`t have worn theeths. It`s a shit place to work under the pedals
__________________
Old 13-04-2010, 01:29 AM   #5
liamford
Trader Score: (0)
yeah that did the trick, but i think it may have worn teeth because it slipped back to the way it was earlier today , try and get new adjuster cheers buddy
Old 13-04-2010, 06:39 AM   #6
grcossie
grcossie's Avatar
Trader Score: (0)
Thats great, a new one and then you are sure, not so expencive.
Cheers mate
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
