Running problem
Old 18-12-2009, 01:24 PM
Leyleeroy
Leyleeroy's Avatar
Default Running problem
Just bought myself a small turbo escort cosworth and it broke down on the motorway on the way home!! it runs ok for about an hour then cuts out and there is no spark but after about 5 mins it will start and run for about another hour any ideas, it seems like something is breaking down when it is getting hot!!
Can anyone help please!!!!!!!!!! i have been at it for about 3 weeks the car has been every where from a cosworth mech to a auto spark and they can not find out what is up with!!!!
P.S does anyone have the correct part number for the EDIS module for the same car???
Old 19-12-2009, 01:16 PM
THE RADMAN
THE RADMAN's Avatar
are you sure its a spark problem? i had something similar once and it was the fuel pump.
the fuse box was breaking down and cutting the pump,then after 20mins or so when it had cooled down it was fine again
Old 19-12-2009, 03:27 PM
martysmartie
martysmartie's Avatar
Check the coil pack.
Martin
Old 20-12-2009, 05:35 PM
saph4be
saph4be's Avatar
crank sensors do this too exactly as described whwn it does it drop a multimeter on the sensor and check the resistance mate
wheelwizardrefurbs
23-09-2015 09:14 PM
Johnsie
Ford Focus ST
08-09-2015 02:39 PM
kosienutter
31
22-08-2015 09:55 AM
Stu @ M Developments
41
21-08-2015 06:47 AM
Zoggon
10-08-2015 10:39 AM
Quick Reply: Running problem
