PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Cosworth
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 04-09-2009, 11:51 AM   #1
liamford
Trader Score: (0)
liamford is an unknown quantity at this point
Default handbrake turn possible in 4x4 escos?
my mate has got a subaru and he recons then when he drives into an open carpark he puts his foot on the clutch and uses the handbrake to put the car into a slide before powering back on to drift,. i thought the handbrake wouldnt lock the back wheels because of the 4wheel drive? or does using the clutch disengage it because there is no drive to the box?. is this possible in an escos???
cheers liam
liamford is offline   Reply With Quote
Old 04-09-2009, 12:12 PM   #2
RUPERT THE BIG HAIRY BEAR
Trader Score: (0)
RUPERT THE BIG HAIRY BEAR is on a distinguished road
alain rupert fitton
yes he is correct in what he saying but get it slightly wrong and ull twist and snap ur prop shafts half shafts diff so risky to do it on rear driven /4x4 cars that i wouldnt bother wasteing ur tyres risk breaking it or crashing it
RUPERT THE BIG HAIRY BEAR is offline   Reply With Quote
Old 04-09-2009, 01:37 PM   #3
jammerrs
Trader Score: (0)
jammerrs is on a distinguished road
yep it can be done, but as said will be in a big twisted heap of metal if it goes wrong
jammerrs is offline   Reply With Quote
Old 04-09-2009, 07:03 PM   #4
oldford
Trader Score: (0)
oldford is an unknown quantity at this point
Even when performed faultlessly there will be some damage to the center diff and the limited slip in the center diff. Do it enough times and you will need to send the limited slip to FF Developments.
And yes, you can see it being done by Group A's and WRC's in rally's. But they have a special clutch in the gearbox that disconnects the rear wheels from the drive train.
oldford is offline   Reply With Quote
Old 04-09-2009, 07:05 PM   #5
Mad Matt
Rally nut
Mad Matt's Avatar
Trader Score: (2)
Mad Matt is an unknown quantity at this point
They have what's called handbrake-release which is an hydraulic system connected to the transfert box directly to the handbrake.
__________________
Olen sveitsista mutta mun sydän on suomea !
Mad Matt is offline   Reply With Quote
Old 04-09-2009, 07:09 PM   #6
ECOS95
Trader Score: (0)
ECOS95 is an unknown quantity at this point
On all 4x4 Cosworths the front & rear wheels are permanently connected so dropping the clutch just disconnects the engine from the transmission nothing else. Pulling the hand brake (depending how good the hand brake is) will just try to lock all 4 wheels through the transimission.
ECOS95 is offline   Reply With Quote
Old 04-09-2009, 07:18 PM   #7
warrenpenalver
Puma Nutter!!!
warrenpenalver's Avatar
Trader Score: (3)
warrenpenalver will become famous soon enoughwarrenpenalver will become famous soon enough
Send a message via MSN to warrenpenalver
why not just use proper car control by learning how wieght transfer effects your car as you lift off, turn in etc. You dont always NEED the handbrake to break away the rear end on a car.
Even on gay wheel drive (FWD ) cars you dont need the handbrake except for the tightest of turns and even then a single sharp tug of the handbrake and handbrake back off again should be all you need to swing the rear round. On my old fiesta and puma thats all i did, a single tap of the handbrake after sharp turn in and lift off and the back end swings right round on its own leaving both hands free to steer out of the turn as you feed in the power to the wheels.
__________________
Medically Discharged!! Officially insane!!!
My Project Thread: http://passionford.com/forum/restora...e-job-fix.html
warrenpenalver is offline   Reply With Quote
Old 04-09-2009, 07:34 PM   #8
cossie690
cossie690's Avatar
Trader Score: (1)
cossie690 is an unknown quantity at this point
my old mk2 fezer did it by it's self.. the thing was fookin brilliant in the snow. so controllable..
wish i still had it tho.
cossie690 is offline   Reply With Quote
Old 04-09-2009, 07:39 PM   #9
warrenpenalver
Puma Nutter!!!
Trader Score: (3)
I had it down to a tee in my last puma as being stripped out it was light at the back and i had perfected it so i would do a handbrake turn perfectly into the car park space i used on base
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
how not to do a handbrake turn!! the youth General Car Related Discussion. 10 27-04-2008 01:10 AM
escos hydraulic handbrake EsCosRacer General Car Related Discussion. 1 13-08-2007 07:56 AM
The Handbrake Turn rstoughy General Car Related Discussion. 12 03-11-2006 06:26 PM
Handbrake problem??? 4x4 saph Tommy Boy Technical help Q & A 2 04-02-2006 07:04 PM
AP 4 pots on rear of escos, handbrake????? ESCYSCOTT General Car Related Discussion. 13 12-11-2004 04:24 PM
