It runs!!! Now what!!
Old 19-09-2008, 10:17 AM
tore_tj
Cossie Paranoia
tore_tj's Avatar
Default It runs!!! Now what!!
Ok.. I've changed coolant temp sensor, act sensor, phase sensor, lambda sensor, de-mulitiplug'd it and the car still behaves like a fckn kangaroo when it hits 4000rpm! What the hell is next? Starts and drives fine..
Old 19-09-2008, 10:26 AM
Dan16v
Dan16v's Avatar
map sensor?
Old 19-09-2008, 10:34 AM
El Grand Tomismola
El Grand Tomismola's Avatar
Checked all your Vac hoses on the car.
Mine popped one off the inlet manifold and it started driving like that.
Also check your throttle position sensor on the throttle body too, that maybe having an adverse cause?
Old 19-09-2008, 10:37 AM
tore_tj
Cossie Paranoia
tore_tj's Avatar
map is new. gonna check the throttle body and vac hoses. Thanks.
Old 19-09-2008, 10:46 AM
R5COS
R5COS's Avatar
dizzy cap if it Big turbo maybe
Old 19-09-2008, 10:50 AM
AlexD
Post Miester !
AlexD's Avatar
have you checked the boost level ?? might be a ht lead breaking down or arching.
Old 19-09-2008, 01:10 PM
tore_tj
Cossie Paranoia
tore_tj's Avatar
it's big turbo. should I turn down the boost and see if it changes?
Old 19-09-2008, 03:10 PM
AlexD
Post Miester !
AlexD's Avatar
Worth a try...... 1st.. If mine ever cuts out i go for the boost level 1st, then the
plugs, then the leads and dizzy cap.
Old 19-09-2008, 03:19 PM
tore_tj
Cossie Paranoia
tore_tj's Avatar
well I'm running only a wee bit over 1bar on greens and msd chip atm so guess it's not that.
Old 19-09-2008, 05:47 PM
paul16v
Monte 087
paul16v's Avatar
Check/cange your alternator? i know it sounds silly but ive seen a few problems similar too yours cured buy this.
Old 19-09-2008, 06:36 PM
JHS
JHS's Avatar
Measure the voltage before even considering changing it though, its not that cheap.
Old 21-10-2008, 06:12 PM
tore_tj
Cossie Paranoia
tore_tj's Avatar
Well.
Some news:
Was feeling a bit flush so forked out for a wasted spark conversion by msd. After some idiot ( me!!) managed to solder like an ass the car wouldn't start. After discovering the "professional" work it started fine.
Noticed the phase sensor plug was fitted the wrong way around when checking all the damn sensors. Don't blame me it was like that when I got it.
Well.. went out in the car and after letting it get warm full throttle in second gear. Pulled almost to the limiter then a small judder. Tried third. Judders when it hits 5k-6k. So it's out of "limp home mode". But what the hell?
Plugs or what? didn't boost more than 1,3-1,5 bar so shouldn't be boost cut.
Getting a bit tired now..
Old 21-10-2008, 06:18 PM
THE RADMAN
THE RADMAN's Avatar
what plug gap are you running?
Old 21-10-2008, 06:30 PM
tore_tj
Cossie Paranoia
tore_tj's Avatar
Old 21-10-2008, 07:01 PM
Dave Henshall
Dave Henshall's Avatar
0.75 with coilpack - and what plugs, 071C's? should be ok - are the screw on tops tight on the plugs.? had mine come loose and cause this.
Old 21-10-2008, 07:23 PM
tore_tj
Cossie Paranoia
tore_tj's Avatar
no idea what plugs. they came with the car and the guy who sold it claimed they were new... Going to check what you have said. Is there any other reason this can happen? So I know what's next if it isn't the plugs..
Old 21-10-2008, 10:02 PM
vinnya77
vinnya77's Avatar
Mine done a similar thing, it turned out to be the loom plugs on the N/S/F wing cut them out, untill I could afford for a new loom to be made.
Old 22-10-2008, 08:38 AM
tore_tj
Cossie Paranoia
tore_tj's Avatar
First thing I did to the car
Old 22-10-2008, 08:44 AM
Gary F
Gary F's Avatar
Try a new set of plugs mate
`spotty
25-09-2015 11:41 PM
dombanks
21-09-2015 08:38 PM
tib2220
14-09-2015 12:33 PM
Eigdoog
13-09-2015 05:46 AM
Quick Reply: It runs!!! Now what!!
