Creaking noise from front end when turning? :(
Old 15-08-2008, 05:32 AM
Lee1972
Formerly COSSIE_LEE
Lee1972's Avatar
Default Creaking noise from front end when turning? :(
Hi, the last couple of days Ive noticed a loud creaking noise which seems to be coming from the front, possibly the suspension when I turn either left or right!
Anyone had the same problem or known what it could be?
Not really got a clue but I guess suspension related?
ta.
Old 15-08-2008, 06:20 AM
dojj
Resident Wrestling Legend
dojj's Avatar
have you got poly's fitted?
they tend to creak if they are drying up so a quick undo and grease up should solve the problem
Old 15-08-2008, 06:29 AM
THE RADMAN
THE RADMAN's Avatar
its normally an indication of knackered suspension top cups,they break up,pop the bonnet and remove the top nut of the shock,remove the top plate and look inside the hole to see if you can see bits of broken metal
Old 15-08-2008, 07:26 AM
ECOS95
ECOS95's Avatar
As said the top mounts would be my guess. Not an expensive part either for a change.
Old 15-08-2008, 07:28 AM
GUZZLER
GUZZLER's Avatar
also can be steering rack loose, had that on a 4x4 saff.
Old 15-08-2008, 08:57 AM
Rippers
Monte Geek
Rippers's Avatar
Also, check on the inside of the car where the steering rack passes through the bulk head and see if the big metal clip is all the way down to the bulk head holding the bushes in properly
Old 15-08-2008, 03:26 PM
Lee1972
Formerly COSSIE_LEE
Lee1972's Avatar
Cheers guys, it does have polys up front hopefully will be just them, if not doesnt sound too exspensive to sort!
Old 16-08-2008, 01:37 PM
cosworth3d
cosworth3d's Avatar
Mine had this and made knackering noises so big change its that
Old 16-08-2008, 05:02 PM
legend289
legend289's Avatar
I`d put money on top mounts, Capris are famous for it.
Old 19-08-2008, 04:08 PM
Lee1972
Formerly COSSIE_LEE
Lee1972's Avatar
If it is the top mounts what would be the better ones to get, Powerflex or Ford standard ones?
Old 19-08-2008, 04:27 PM
JHS
JHS's Avatar
Not talking about the bushes, but the metal "cup"
Old 19-08-2008, 04:47 PM
Lee1972
Formerly COSSIE_LEE
Lee1972's Avatar
Ah right, so does that mean the front shocks need replacing?
Old 19-08-2008, 04:49 PM
El Grand Tomismola
El Grand Tomismola's Avatar
No the cup is seperate to the bush and shocker
Old 19-08-2008, 04:56 PM
ickey818
ickey818's Avatar
Had exactly the same problem on my 4x4 saph last month, changed the top mount metal cups and the bearings. Haven't heard a creak from it since.
The parts weren't expensive from Ford, think I paid about Ł20 for the 2 cups and bearings.
Old 19-08-2008, 04:59 PM
Lee1972
Formerly COSSIE_LEE
Lee1972's Avatar
Is that all i will need from fords, the cups and bearings?
Old 19-08-2008, 05:30 PM
THE RADMAN
THE RADMAN's Avatar
yes,you may as well do the bearings while you have the shocks out and all stripped down
Old 19-08-2008, 05:49 PM
Lee1972
Formerly COSSIE_LEE
Lee1972's Avatar
Old 20-08-2008, 12:12 PM
rsdene
rsdene's Avatar
same as mine, this should short your problem out mate
Old 24-08-2008, 03:19 AM
Lee1972
Formerly COSSIE_LEE
Lee1972's Avatar
Thanks to everyone for the help, just to let you know dojj was right, top cups were fine and it was the poly bushes causing the noise!
malkiemac3579
14-07-2017 12:10 PM
Wilsfoci
15
30-03-2016 10:26 PM
Bezzy41
03-08-2015 10:31 AM
Quick Reply: Creaking noise from front end when turning? :(
