hub nuts
Old 02-08-2008, 12:35 PM
ossie cossie
ossie cossie's Avatar
Default hub nuts
what size socket,s do i need for the rear drive shaft to hub nuts and also are the front ones the same size, if not what size are they? Thanks.
Lastly what is the best way to change the rear springs without having to disconect the rubber brake pipe hoses, Can it be done or should i just bite the bullet. i want to fit some lowered springs the ones i have are Eibach Federn part no.s EW3503201VA and EW3503202HA any body know the spring rates and how much they will lower the car?
Old 02-08-2008, 01:25 PM
Rippers
Monte Geek
Rippers's Avatar
rear nuts 41mm
front nuts 30mm
Old 02-08-2008, 01:31 PM
Kelv
Almost there!
Kelv's Avatar
As above.
damn them odd 41mm rears
Old 02-08-2008, 03:42 PM
THE RADMAN
THE RADMAN's Avatar
apart from the obvious bits,disconnect the rear brake t piece from the car,the bolt will prob be rusted so give it a good soaking of wd40 etc,disconnect the rear drive shafts joints at the outer ends then you can carefully lower down the arms and brake pipes without having to undo the brakes pipes them selves,the eibachs will drop it around 40mm or so
Old 05-08-2008, 08:46 PM
dojj
Resident Wrestling Legend
dojj's Avatar
and one side goes round the wrong way to undo
Old 05-08-2008, 10:19 PM
kennyA
kennyA's Avatar
Originally Posted by Kelv
As above.
why not just get them reworked, down to 36mm.
Sierrasideways
08-10-2015 06:37 PM
fordrallycar
30-09-2015 07:57 PM
DavidK
27-09-2015 02:55 PM
jc1989rs
05-09-2015 08:09 PM
Quick Reply: hub nuts
