Escort Front Bumper
Old 29-07-2008, 01:32 PM
auralisRS
auralisRS's Avatar
Default Escort Front Bumper
I am in the process of resitting my front bumper on my Escort, it appears like its too far forward (step when looking at front side wheel arch - side on) and its tipped forward so the lower splitter is quite low.
I have both the side black keys in place, so I can't see how it will go back some more or tip for that matter.
Has anyone had or got any experience with them that they would share with me.
Thanx
Old 29-07-2008, 01:40 PM
Rippers
Monte Geek
Rippers's Avatar
There are two 17mm bolts either side underneath that bolt the bumper to chassis. loosen them and you should be able to move the front bumper forwards and backwards.
There are also to adjustibles under neath the middle of the bumper with torx heads this adjust the height, but do not undo them fully.
HTH
Old 29-07-2008, 02:04 PM
auralisRS
auralisRS's Avatar
Hi there.
Thank you very much for your quick response. Can you be more specific on the whereabouts of the 17mm bolts, are they on edge or inward more, are they clearly visible from underneath, the car is wheel less on axle stands at moment, so access is ok.
Old 30-07-2008, 11:30 AM
Rippers
Monte Geek
Rippers's Avatar
If you have the original under tray you will have to remove the front parts and the air dams it to gain access to them. Just follow the chassis rail to the front where they meet the bumper to locate them
Old 30-07-2008, 03:22 PM
Rippers
Monte Geek
Rippers's Avatar
These are the in/out adjusters one each side
these are the height adjusters
Old 01-08-2008, 10:23 AM
auralisRS
auralisRS's Avatar
Hi all
Ok, the bumper is off to do some cosmetic work on the lower splitter and have a general spring clean behind it as well as change the PAS pump. Thank you to you guys for your guidance, I did manage to lift the front up a bit with the adjusters before I took it off. So again thank you.
One thing I must ask is this, on the sides of the bumper where it locates top and bottom. The top slides into its slot, the bottom had the key that you push and turn to lock. This top slot has a hole through it on the actual bumper and on the chassis, like a fastener should be fitted to hold it in the slot, is this right, cos mine had none.
Old 01-08-2008, 11:07 AM
THE RADMAN
THE RADMAN's Avatar
the bumper just slides into the top cup then the bottom fixing has the twist in connector like these,nothing else is fitted to it
http://cgi.ebay.co.uk/GENUINE-FORD-E...3286.m14.l1318
Old 01-08-2008, 02:04 PM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
radman off topic did you coming to ford fair i have a black lid for you to look at for you power steering you asked about ages ago
Old 01-08-2008, 05:22 PM
THE RADMAN
THE RADMAN's Avatar
yep, ill pm my number to you, forgotten all about that
jessie_rs
11
03-06-2019 04:57 PM
andy130
15-03-2016 07:59 AM
Gary @ RS CLASSICS
11
10-09-2015 06:49 AM
C2 MAK
20-08-2015 09:46 PM
Quick Reply: Escort Front Bumper
