p8 ecu
Old 20-07-2008, 11:16 PM
babscossie
babscossie's Avatar
Default p8 ecu
evening guys.
does a standard p8 ecu have a pectal board or is that a mod?? (escos 1992)
i ask this due to mine is running a pectal board with map for greys etc. i've just rebuilt the engine and have a p8 stage one chip that i was going to run the engine in with.
problem is when i fit the stg 1 chip to the pectal board, i loose inj pulse and spark.
then put the other chip in 'for greys' and all pulses are back.
do i need to take the pectal board out and run the stg 1 chip direct
cheers
Dave
Old 21-07-2008, 10:01 AM
grcossie
grcossie's Avatar
P8 don`t have any boards as standar. It depends if the chip are made fore board or not, i have bouht, some chips whit, and some whitout
Old 21-07-2008, 05:14 PM
Dave Henshall
Dave Henshall's Avatar
std p8 has no board and is just a chip, usually phase 0/1 chips wont have a board either and will plug straight in the main board.
plugging your stg1 chip into a pectel board will more thaqn likely loose spark and injector pulse as the board is a decrpytion board to decrypt the software in the chip.
Old 21-07-2008, 05:27 PM
Kelv
Almost there!
Kelv's Avatar
and also - a stage one chip may be setup to run on standard injectors or maybe even greens etc, so wont be correct for fueling for greys.
id just stick with the chip/map thats specific for that engine and run it in as normal.
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
griffo69
04-10-2015 11:58 AM
R4N SS
Ford XR Parts For Sale
15-09-2015 03:38 PM
DixieTheKid
14-09-2015 09:04 PM
Tank Mike
14-09-2015 03:56 PM
Quick Reply: p8 ecu
