big and small turbo
Old 13-06-2008, 05:49 PM
sean2k
sean2k's Avatar
Default big and small turbo
hi all wots the diffence in the big and small turbo 4 escort cossies ie make and bhp cheers sean2k
Old 13-06-2008, 06:11 PM
georgie1
georgie1's Avatar
hi m8 small turbo t25 big turbo is t3 i think they got the same power but small turbo has no lag where big turbo has lag but the big turbo can be more tune where small turbo need more money to get big power i have a small turbo
Old 13-06-2008, 06:21 PM
pa_sjo
Colossal Pervert
pa_sjo's Avatar
The later Escort Cosworth is just a refined version of the earlier one.. different turbo/head/injectors/management/etc... Early cars had a hybrid T34 turbocharger, later ones had a hybrid T28.. both produce similar power in stock form.. as above, the later cars aren't as easy to extract power from - but anything is possible!
Old 13-06-2008, 09:04 PM
sean2k
sean2k's Avatar
wot do u class as early cars tho?
Old 13-06-2008, 09:08 PM
sean2k
sean2k's Avatar
also can sum 1 go though al the turbos 4 the ford ie t3 wot the hell does tyhat mean
Old 13-06-2008, 09:09 PM
pa_sjo
Colossal Pervert
pa_sjo's Avatar
The early/late cars are completely different.. Changed in 1996 I believe.
Old 13-06-2008, 09:11 PM
rapidcossie
rapidcossie's Avatar
they didnt have "hybrid" turbos as standard.
Old 13-06-2008, 09:12 PM
georgie1
georgie1's Avatar
it diffrent sizes t28,t3,t3.4,t4 then u got ur gt30 come on people help him out as i dont know to much
Old 13-06-2008, 09:13 PM
georgie1
georgie1's Avatar
i thought mine was a t25 not t28 and i agree hybid is not standard wish it was lol
Old 13-06-2008, 09:29 PM
MarkN
MarkN's Avatar
They changed in 1994. J and K platers are large turbos, L is a crossover year but mostly large, then M, N and P are small, but some may have been converted to large.
Old 13-06-2008, 09:30 PM
pa_sjo
Colossal Pervert
pa_sjo's Avatar
I think you'll find it is a hybrid. A hybrid developed by Garrett for Ford. All Ford RS turbochargers are 'hybrids'.
Old 13-06-2008, 09:31 PM
rapidcossie
suppsoe escorts came with t35s too
Old 13-06-2008, 09:42 PM
pa_sjo
Colossal Pervert
pa_sjo's Avatar
No such thing as a T35.. Early Escort Cosworths came with the TBO34, or T34 as it's commonly referred to.. T3 turbine, T4 compressor.. Hybrid.
Old 13-06-2008, 09:47 PM
georgie1
georgie1's Avatar
so what i got then m8 as it a small turbo on a n plate and i dont think it hybrid as that about 800 pound
Old 13-06-2008, 09:50 PM
pa_sjo
Colossal Pervert
pa_sjo's Avatar
The later car comes with a T28 turbocharger.. again a hybrid unit made for Ford by Garrett.. T3 compressor wheel in a T25 housing..
Old 13-06-2008, 09:53 PM
georgie1
georgie1's Avatar
how can i know for sure mine is a n plate and if it has yippee
Old 13-06-2008, 09:55 PM
pa_sjo
Colossal Pervert
pa_sjo's Avatar
It should say on the label on the front of the turbo.. assuming it's still got the original turbo and ID plate on it.
Old 13-06-2008, 09:59 PM
georgie1
georgie1's Avatar
i will have to have a look cant say i seen a label but my car only done 42000 miles
Old 14-06-2008, 10:06 AM
GUZZLER
GUZZLER's Avatar
1994 was the change over year from big to small turbo, you see a good mix of small & big turbos on an M plate, early small turbos still had the big mirrors & early badging on the tailgate.
small turbo had a fuel flap instead of a visable cap, it also had a different engine, YBP with oil squirt jets as standard & the head was meant to flow better, different exhaust, inlet manifolds, managment & turbo but most of the running gear was the same.
Old 14-06-2008, 11:16 AM
cosworth3d
cosworth3d's Avatar
small turbo
Big turbo (only this is an T3 sierra turbo instead of een T35 but this is the difference in the underbonnet look)
Old 14-06-2008, 11:27 AM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
the cross over from big turbo to small was about AUG 1995...
Old 14-06-2008, 01:25 PM
Rippers
Monte Geek
Rippers's Avatar
There where loads of differences between the BigTurbo/Small Turbo change over was mid 1994
Full filler cap to flap as mentioned above
Wing mirrors flappy to tear drop
Extra wind proofing seals on the b-pillar and bottom door frame
Rear Badging positions and type
Certain colours phased out and added ie I've never seen a Pacifica or Polais Small turbo and I've never seen a auralias Big Turbo etc
I think all Small turbos where Lux spec as well ie all had sunroofs and electrics etc
Engine wise Big turbo had the larger T34 turbo and the classic blue cam cover.
Small turbo had a Smaller T25 turbo different Exhaust manifold, different inlet manifold, throttle body, ISCV, oil kidney/flame trap, different head, cam cover, different ignition leads and coil packs, different timing belt cover, oil spray jets under the pistons, different ECU which used different sensors (crank/phrase etc), MAF sensor on the different airbox lid, recirc valve came directly off the turbo, Fuel rails where painted black for some reason on the Small turbos aswell.
Old 14-06-2008, 01:29 PM
Rippers
Monte Geek
Rippers's Avatar
Originally Posted by cosworth3d
Hate to say but that is a very poor example of a big turbo bay.
It has a Sierra Turbo and turbo heat shield, Sierra cam cover, Sierra cam pulley cover, Small turbo fuel rail and a sierra Alternator.. its got to be a build up doesn't even have the vins plates
This is what a Big Turbo bay looks like
Old 14-06-2008, 01:56 PM
sean2k
sean2k's Avatar
wots the diffence between t34 and t25? wot does all the letters and numbers mean? cheers sean2k
Old 14-06-2008, 03:04 PM
Rippers
Monte Geek
Rippers's Avatar
Basically the T34 is a bigger laggier turbo which comes on boost later which is capable of being tuned upto 350 bhp
The T25 is a smaller less laggier turbo which comes on boost sooner but is only tunable upto about 280bhp
In standard/stage1 tuned state the T25 is better as the boost there earlier. the big turbo is better for more power thou
They are phyically different in size and the T25 has a triangular looking take off on the front housing for a recirc (no noise dumo valve)
Old 14-06-2008, 08:40 PM
cosworth3d
cosworth3d's Avatar
Your totally right i could not find the right picture so soon
Old 15-06-2008, 05:15 PM
sean2k
sean2k's Avatar
thanks lads 4 the info cheers sean2k
Old 17-06-2008, 07:54 PM
sean2k
sean2k's Avatar
is the escort cossie teh same 4 both 4x4 and 2wd ie engine and gearbox
Old 17-06-2008, 08:04 PM
ECOS95
ECOS95's Avatar
The Escort only came as 4x4.
Old 17-06-2008, 09:38 PM
GUZZLER
GUZZLER's Avatar
'94
Old 18-06-2008, 07:46 PM
sean2k
sean2k's Avatar
all escort cossies r 4x4 then?
Old 18-06-2008, 09:01 PM
S1rst
S1rst's Avatar
Yes there all 4x4 mate. I have a small turbo by the way and love it.
Old 19-06-2008, 07:51 AM
ECOS95
ECOS95's Avatar
yep, the MK4 0r Mk5 RS2000 came as 2wd & 4wd. You could be getting confused with that. Some people do convert their Escort to 2wd also.
Old 19-06-2008, 07:21 PM
redrsmk5
redrsmk5's Avatar
Originally Posted by GUZZLER
'94
yep correct mines one of the change over cars of which im reliably informed there were 27 of
Old 20-06-2008, 07:56 AM
S1rst
S1rst's Avatar
My mate had an M plate 94 small turbo with big turbo fuel cap, bt mirrors and bt badge layout.
Old 20-06-2008, 05:23 PM
sean2k
sean2k's Avatar
hi there can sum 1 send me sum pics of the big turbo and small turbo in the diffence ie bodywork i ant geting this at all
Matt Baxter
16-09-2015 08:30 PM
Cosnada
27-08-2015 09:15 AM
IAN RS2k
18-08-2015 07:51 PM
Blown Hell
05-08-2015 07:22 AM
marky_g
03-08-2015 04:45 PM
Quick Reply: big and small turbo
