PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Cosworth
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 28-05-2008, 04:45 AM   #1
Lee1972
Formerly COSSIE_LEE
Trader Score: (0)
Lee1972 is an unknown quantity at this point
Default Annoying alternator belt squeak, any ideas?
Ive got an annoying squeak when the engines running which I was told I needed my alternater belt replacing and that'll cure it.
I replaced one belt then after about a month the squeak came back so I replaced it again and low and behold the squeak is back!
Anyone got any ideas as what it might be thats causing it to squeak?
Lee
Lee1972 is offline   Reply With Quote
Old 28-05-2008, 05:54 AM   #2
Daveysaff
Skint Passionford User
Trader Score: (8)
Daveysaff is an unknown quantity at this point
Dave Caraher
Send a message via MSN to Daveysaff
belt too tight?
__________________
I'm gonna finish it soon....... Honest
MEATPIES!
help support C.R.A.P!!!
Daveysaff is offline   Reply With Quote
Old 28-05-2008, 06:01 AM   #3
ossie cossie
ossie cossie's Avatar
Trader Score: (0)
ossie cossie is an unknown quantity at this point
Dont know if it will help but i had a simmilar problem with mine and i found the powersteering pump bolts were loose i tightened them up (after changing the belt) and it went away. try that.
__________________
ossie cossie is offline   Reply With Quote
Old 28-05-2008, 06:04 AM   #4
Lee1972
Formerly COSSIE_LEE
Trader Score: (0)
Quote:
Originally Posted by Daveysaff View Post
belt too tight?
Wouldnt that squeak from when it was put on though? And the chances of 2 new belts being put on too tight by 2 different Ford mechanics...? Im not sure although im no expert?
Old 28-05-2008, 06:05 AM   #5
Lee1972
Formerly COSSIE_LEE
Trader Score: (0)
Quote:
Cheers, its going for a service next week, i'll mention it.
Old 28-05-2008, 08:21 AM   #6
TiB
Trader Score: (1)
TiB is an unknown quantity at this point
Send a message via MSN to TiB
I'd say the hole in the alternater mounting block is ovaling causing the alternater to sit slightly twisted.
__________________
TiB is offline   Reply With Quote
Old 28-05-2008, 10:09 AM   #7
Trader Score: (0)
tabetha will become famous soon enough
Try some TALCUM powder on the belt, see if it helps.
tabetha is offline   Reply With Quote
Old 28-05-2008, 03:38 PM   #8
Lee1972
Formerly COSSIE_LEE
Trader Score: (0)
Quote:
Did try grease and that worked until it worn off, didnt cure the problem
Old 28-05-2008, 03:39 PM   #9
Lee1972
Formerly COSSIE_LEE
Trader Score: (0)
Quote:
So to someone that knows (not me!) the alternater will look out of position then?
Old 28-05-2008, 05:07 PM   #10
Kelv
Almost there!
Kelv's Avatar
Trader Score: (4)
Kelv is an unknown quantity at this point
id say its not aligned properly, the grease will work temporarily, as will replacing the belt.
just check everything that it revolves around to ensure everything is tight, it would only need one bolt to be the slightest bit loose and something wont sit quite so square to what it should be.
i definatly wouldnt say the belt is to tight as its on a sprung loaded tensioner.
__________________
EscortRSCosworth.com
Kelv is offline   Reply With Quote
Old 28-05-2008, 10:26 PM   #11
GUZZLER
GUZZLER's Avatar
Trader Score: (3)
GUZZLER is an unknown quantity at this point
as Kelv said the belt is not tightened manually, it has an auto tensioner, sometimes the auto tensioner gets weak & lets the belt get a bit slack thus causing noise.
__________________
GUZZLER is offline   Reply With Quote
Old 29-05-2008, 08:33 AM   #12
Lee1972
Formerly COSSIE_LEE
Trader Score: (0)
Quote:
That maybe the problem then, i'm off down to Fords later today don't suppose youve got the FINIS code for the part i'd need?
Would be very grateful
Lee
Old 29-05-2008, 09:14 AM   #13
dojj
Resident Wrestling Legend
dojj's Avatar
Trader Score: (3)
dojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the roughdojj is a jewel in the rough
it could also be that the belt that was originally causing the squeek has left some residue on the pulleys which has now transfered itself onto the new belt
this should be fairly easily visable theough and it was much more prevalent on the V belts than the serpentine ones which i think you would be refering to if it's an auto tensioner
dojj is offline   Reply With Quote
Old 30-11-2009, 08:01 PM   #14
Chuffter
Trader Score: (0)
Chuffter is on a distinguished road
Did you find the solution? I've got the same problem however it only starts to squeak after the car has warmed up?
Chuffter is offline   Reply With Quote
Old 09-12-2009, 03:24 AM   #15
Lee1972
Formerly COSSIE_LEE
Trader Score: (0)
Quote:
Nah never found the problem, did get one of the pulleys (cant remember which one though) but couldnt find anyone to do the job would you believe! Changed the belt a couple of times then sold it...
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
alternator belt RS craig 71 Technical help Q & A 7 28-03-2008 08:49 PM
Alternator belt krisberic Ford Sierra / Sapphire / RS500 Cosworth 4 28-03-2007 05:19 PM
s2 Alternator belt Craigb Ford Escort RS Turbo 1 03-02-2007 07:01 PM
ADJ ALTERNATOR BELT?? COSSIE 1 Ford Escort RS Turbo 3 29-01-2006 04:38 PM
Alternator Belt.... SapphyMike General Car Related Discussion. 2 24-09-2004 03:36 PM
