Running on 3.....
Running on 3.....
OMEX / FRS injectors / Coil packs.
Changed plugs and one had split in half, but on fitting new ones, it is still the same.
No smoke, no water loss, car idles and drives like a Scooby, with at the moment, the same sort of power.
Any other possibilties?
head gasket blown between cylinders?
I had exactly the same symptoms on an old clio i had (sounding like it was running on 3) - changed the plugs, HT's, Coil, u name it i changed it! - still ran the same
someone suggested my Head gasket may have gone, i was like "Yeah, as if, am sure i'd know if that happend".......so i whipped the head off to find that the gasket had indeed split between the 2 middle cylinders so they were loosing compression between each other! stuck a new gasket on, job done!
Eigdoog
13-09-2015 05:46 AM
