| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Cosworth This forum is for discussion of all things pertaining to the Ford Escort Rs Cosworth. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#41 | ||||
Trader Score: (0)
Rep Power: 8 ![]() |
#42 |
Almost there!
__________________
EscortRSCosworth.com
#43 |
Could be booking into Reylands so For the barra kit and Hydraulic conversion !
__________________
![]() CheeRS Alan. |
#44 |
__________________
Rainbird-'' Prices are on my website'' I say- "mike that quotes annoying'' Rainbird-" not as annoying as having a website that noone looks at" ![]() ![]() Moonstone Blue 3dr Cosworth- Standard 8000 miles. Black 3dr Cosworth- 520hp in the making. Black RS500- 350hp. White 3dr Cosworth- 560hp. Red Escort Cosworth. 200Miles!! Silver Focus ST- 300hp. Performance Blue Focus RS mk2- Standard. |
#45 |
hi lads
just to put the record striaght ............. the bara striaght cut kit , is not that noisey compaired to other striaght cut boxes all it sounds like is any "normal " car going in reverse , it's not that intrusive at all it's liveable in a road car cheers marco
__________________
![]() ![]() escort cosworth Grp N rwd in the making http://passionford.com/forum/restorations-rebuilds-and-projects/207127-groupn-escort-cos-fuel-tank-lift-pumps-swrilpot-twin0440-fuel-pumps.html
#46 |
Romain
Hi,about my gearboxes and gearkits....we built this kit in north italy with very good materials.the are actually 3 options.
1. straight cut,new shafts,modified syncro on CNC machine for fast gear change.1st gear its a little longer than standard, 2nd 3rd 4th are shorter and 5th a little longer 168miles at 7000rpm 2.semi-straight helical gears (less Noise),new shafts,modified syncro on CNC machine for fast gear change.1st gear its a little longer than standard, 2nd 3rd 4th are shorter and 5th a little longer 168miles at 7000rpm 3.straight cut,new shafts,modified syncro on CNC machine for fast gear change.all 5 gears are shorter than standard,in this gearbox we use an alloy spacer between gearbox case and transferbox.Ideal for track days and rally. all gearkit can handle between 500hp 550nm and 600hp 700nm we offer the full rebuild gearboxes plus fitting gearkit (like new case,new seals,new bearings and fitting gearkit) Customers send us standard MT75 gearboxes in any conditions and than we return it back in new conditions. cheers Oppliger Romain
__________________
Oppliger Romain COSWORTH SPECIALISTS web: www.oppligermotorsport.com email: oppliger.cosworth@tiscali.it facebook: http://www.facebook.com/pages/Opplig...31522163564280 |
#47 |
so what would be the best box if I was running a stage 3 escort cosworth?
__________________
a FORD owner, very rare on hear |
#48 |
Standard. The clutch might need doing depending on how you drive it. I'm planning on running standard transmission but a AP Racing Organic clutch. Thats with my goal of 350 BHP, fingers crossed.
#49 |
I have a uprated clutch in there already
we will have a very simular spec mate, what intercooler are u running?
__________________
#50 | |
Cossie Paranoia
Trader Score: (0)
Rep Power: 6 ![]() |
Quote:
Price?
__________________
#51 |
Romain
2500£
__________________
#52 |
Cossie Paranoia
Trader Score: (0)
that's just for the internals right? have you got any pics or any demo car?
__________________
#53 |
I've got a BT Intercooler/Charge cooler with cold water kit to go on, hopefully this should do the job. The ACT gauge won't lie if its not up to the job.
#54 |
i have a RS500 Pro Alloy intercooler
__________________
#55 |
__________________
#56 |
I've seen on rallycarsforsale.net that oppliger sells this kits/box for 1800 punds... Not 2500!?
__________________
-1993 Ford Escort Cosworth -2000 Audi A4 2,5tdi Quattro |
#57 |
__________________
#58 | |
Quote:
sorry just seen this ....... not the sequentail isn't going to happen bara has looked into it he says thats the barrels for a sequentail to fit in the mt75 casing are too small if he did make one it would phyiscally hurt your hand after 20mins the next bigger size barrells wouldn't fit in the casing they would have been ideal would have made a nice and easy gear change if the casing was 25mm taller would have been ok and would work out far too much to make a new casing marco
__________________
![]() ![]() escort cosworth Grp N rwd in the making http://passionford.com/forum/showthread.php?t=207127
#59 |
Cheers for the reply Marco, even though not good news
Do you know of anyone who makes a decent sequential for 2wd Cheers Dave |
#60 |
yes quafie do a sequentail mt75 but it will defo hurt your hand after a while
__________________
#61 |
Hi marco
Have you heard of Elite transmitions? Just wondered what their sequentials might be like ? |
#62 |
what do you guys mean it will hurt your hand?
__________________
#63 |
Romain
1800£ is for the standard ratio gearkit,does not include building up!
2500£ is for the short ratio gearkit with extra parts inside gearbox
__________________
#64 | |
Capt Chaos
Quote:
__________________
500+BHP 4X4 ZAKSPEED ESCORT GROUP 5 FULL RESTO, SOON TO LOOK LIKE THIS,, ![]() ![]() TAKE A LOOK AT MY GROUP 5 ZAKSPEED ESCORT REPLICA RESTORATION Clicky |
#65 |
Romain
first road test of our powerful Cosworth car....1.6 bar of boost....we have to finish the map for 2.2bar...
engine spec:Nikasil liners on 200 block,10 long studs,Arrow cranckshafts,Arrow rods,forged pistons,ported head,double valve springs,Nimonic valves,solid followers,wild camshafts,wrc 8 injectors manifold,swedish plenum,70mm body,tubolar exhaust manifold,gt35 turbo,external wastegate,coil pack,pectel super 8,twin 044 fuel pumps,etc....ops....Oppliger BIG TOOTH GEARKIT videos:
__________________
#66 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Quote:
Previous Thread
Next Thread
